New operator question (3 point hitch)
/ New operator question (3 point hitch) #1
geosnooker2000
Somerville, TN
Ford 4000 diesel
I am going to accumulate a few implements in the next couple of weeks and I have a hauling and unloading question. I have one of those standard 5X8 mesh floor trailers with the fold-up ramp on the back ( like this https://www.tractorsupply.com/tsc/p...8-ft-open-mesh-floor-utility-trailer-1090202? crmid=7662966485&utm_source=google&utm_medium=pmax&utm_campaign=tsc0_tth_tsc_cat_search_sch_us_cvr&utm_content=sku_na&adtype=pla&campaignid=22258948704&device=c&product_channel=local&product_id=1090202&store_code=1531&gad_source=1&gad_campaignid=22269434356&gbraid=0AAAAADnTm20qBW6baXqCCMFx9zNEJAoIo&gclid=Cj0KCQiAk6rNBhCxARIsAN5mQLsVYoJEUEIIuc0OQJno1DGpmbHamoVPwbGW4QsdiGLtPt7bU3h-S4QaAuBxEALw_wcB. ) I have done a little research and found that a 6' bushhog weighs about 1000lbs. If I get the guy I'm buying it from to load it from the side, is my 3 point hitch on my 1968 Ford 4000 going to be able to reach high enough to hook up and lift it up and off the trailer?
/ New operator question (3 point hitch) #5
It will with a good boom pole.
/ New operator question (3 point hitch) #6
He must have a large tractor to pick up 600-800# 6' behind the rear axle with a 3-pt boom, which must also be very heavy built.
/ New operator question (3 point hitch) #7
Back the trailer wheels into a low spot or a small ditch. Or unhook and raise the front of the trailer.
/ New operator question (3 point hitch) #8
A properly functioning 68 Ford 4000 will easily pick up an 800 pound weight with a good boom pole. Note, "good."
Duly noted. "GOOD" boom pole...
Right now I'm hunting a good 16' trailer with no side rails (like a car hauler) to buy and transport implements. I found a 4 row planter for sale, for instance. It's too big for anything other than a car hauler-type trailer, and I have no idea how much it weighs.
/ New operator question (3 point hitch) #11
I assumed it would just sit on top of the side rails. I have abandoned that idea, though. Looking for a good 16' trailer with no side rails.
Do you have any trees you can put a come-a-long over a limb? You just have to lift the front of the mower and drive the trailer out from under it. Just be sure the rear tire has something to roll on.
/ New operator question (3 point hitch) #14
A boom pole is cheap at TSC,
But you might not have enough tractor for a 4 r planter.
2 row would fit better on tractor.
A 4000 is supposed to be 62HP according to TractorData. This won't be a no-till situation until next year.
/ New operator question (3 point hitch) #17
If my math is right, lifting 800# with a 6' boom attached to 3' lift arms results in a leverage of 7200# off the front axle, which weighs approx.2500-3000# without a FEL or front weights.
/ New operator question (3 point hitch) #18
Might not want to use the long hook.
I've lifted old (heavy), 5' rotary cutter with boom pole on 8N many times without incident.
I think I'm gonna find a tree branch to drive under and wench it up and drive out from under it and then lower it down. The problem will be finding a branch in the right position. Thanks for all the ideas!
/ New operator question (3 point hitch) #20
52 PTO Horsepower and 47 at the drawbar unless it's pre 1968 model and then it's roughly 5 HP less. It will handle a 4 row planter fine.
As for unloading the brush cutter if you use a tree limb don't stand under it. The 3 pt does have a 3200 lb rating at the arm tips so that's pretty respectable. A boom pole could be a good investment. Most have an attachment point about midway on the boom with a much higher lifting capacity. Good luck!
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
