New operator question (3 point hitch)
/ New operator question (3 point hitch) #1
geosnooker2000
Somerville, TN
Ford 4000 diesel
I am going to accumulate a few implements in the next couple of weeks and I have a hauling and unloading question. I have one of those standard 5X8 mesh floor trailers with the fold-up ramp on the back ( like this https://www.tractorsupply.com/tsc/p...8-ft-open-mesh-floor-utility-trailer-1090202? crmid=7662966485&utm_source=google&utm_medium=pmax&utm_campaign=tsc0_tth_tsc_cat_search_sch_us_cvr&utm_content=sku_na&adtype=pla&campaignid=22258948704&device=c&product_channel=local&product_id=1090202&store_code=1531&gad_source=1&gad_campaignid=22269434356&gbraid=0AAAAADnTm20qBW6baXqCCMFx9zNEJAoIo&gclid=Cj0KCQiAk6rNBhCxARIsAN5mQLsVYoJEUEIIuc0OQJno1DGpmbHamoVPwbGW4QsdiGLtPt7bU3h-S4QaAuBxEALw_wcB. ) I have done a little research and found that a 6' bushhog weighs about 1000lbs. If I get the guy I'm buying it from to load it from the side, is my 3 point hitch on my 1968 Ford 4000 going to be able to reach high enough to hook up and lift it up and off the trailer?
/ New operator question (3 point hitch) #5
It will with a good boom pole.
/ New operator question (3 point hitch) #6
He must have a large tractor to pick up 600-800# 6' behind the rear axle with a 3-pt boom, which must also be very heavy built.
/ New operator question (3 point hitch) #7
Back the trailer wheels into a low spot or a small ditch. Or unhook and raise the front of the trailer.
/ New operator question (3 point hitch) #8
A properly functioning 68 Ford 4000 will easily pick up an 800 pound weight with a good boom pole. Note, "good."
Duly noted. "GOOD" boom pole...
Right now I'm hunting a good 16' trailer with no side rails (like a car hauler) to buy and transport implements. I found a 4 row planter for sale, for instance. It's too big for anything other than a car hauler-type trailer, and I have no idea how much it weighs.
/ New operator question (3 point hitch) #11
I assumed it would just sit on top of the side rails. I have abandoned that idea, though. Looking for a good 16' trailer with no side rails.
Do you have any trees you can put a come-a-long over a limb? You just have to lift the front of the mower and drive the trailer out from under it. Just be sure the rear tire has something to roll on.
/ New operator question (3 point hitch) #14
A boom pole is cheap at TSC,
But you might not have enough tractor for a 4 r planter.
2 row would fit better on tractor.
A 4000 is supposed to be 62HP according to TractorData. This won't be a no-till situation until next year.
/ New operator question (3 point hitch) #16
That's engine HP.
About 50 on the PTO.
About 40 on the drawbar.
/ New operator question (3 point hitch) #17
If my math is right, lifting 800# with a 6' boom attached to 3' lift arms results in a leverage of 7200# off the front axle, which weighs approx.2500-3000# without a FEL or front weights.
/ New operator question (3 point hitch) #18
Might not want to use the long hook.
I've lifted old (heavy), 5' rotary cutter with boom pole on 8N many times without incident.
I think I'm gonna find a tree branch to drive under and wench it up and drive out from under it and then lower it down. The problem will be finding a branch in the right position. Thanks for all the ideas!
/ New operator question (3 point hitch) #20
52 PTO Horsepower and 47 at the drawbar unless it's pre 1968 model and then it's roughly 5 HP less. It will handle a 4 row planter fine.
As for unloading the brush cutter if you use a tree limb don't stand under it. The 3 pt does have a 3200 lb rating at the arm tips so that's pretty respectable. A boom pole could be a good investment. Most have an attachment point about midway on the boom with a much higher lifting capacity. Good luck!
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2006 Hypac C530AH Pneumatic Wheel Compactor (A64553)
2006 Hypac C530AH...
2013 Caterpillar Warren Power Systems WCW84MH 8KW Portable Light Tower (A64194)
2013 Caterpillar...
2025 JMR Stump Bucket Skid Steer Attachment (A64553)
2025 JMR Stump...
Bigfoot Yard Art (A64557)
Bigfoot Yard Art...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
