New operator question (3 point hitch)
/ New operator question (3 point hitch) #1
Somerville, TN
Ford 4000 diesel
I am going to accumulate a few implements in the next couple of weeks and I have a hauling and unloading question. I have one of those standard 5X8 mesh floor trailers with the fold-up ramp on the back ( like this https://www.tractorsupply.com/tsc/p...8-ft-open-mesh-floor-utility-trailer-1090202? crmid=7662966485&utm_source=google&utm_medium=pmax&utm_campaign=tsc0_tth_tsc_cat_search_sch_us_cvr&utm_content=sku_na&adtype=pla&campaignid=22258948704&device=c&product_channel=local&product_id=1090202&store_code=1531&gad_source=1&gad_campaignid=22269434356&gbraid=0AAAAADnTm20qBW6baXqCCMFx9zNEJAoIo&gclid=Cj0KCQiAk6rNBhCxARIsAN5mQLsVYoJEUEIIuc0OQJno1DGpmbHamoVPwbGW4QsdiGLtPt7bU3h-S4QaAuBxEALw_wcB. ) I have done a little research and found that a 6' bushhog weighs about 1000lbs. If I get the guy I'm buying it from to load it from the side, is my 3 point hitch on my 1968 Ford 4000 going to be able to reach high enough to hook up and lift it up and off the trailer?
/ New operator question (3 point hitch) #5
It will with a good boom pole.
/ New operator question (3 point hitch) #6
He must have a large tractor to pick up 600-800# 6' behind the rear axle with a 3-pt boom, which must also be very heavy built.
/ New operator question (3 point hitch) #7
Back the trailer wheels into a low spot or a small ditch. Or unhook and raise the front of the trailer.
/ New operator question (3 point hitch) #8
A properly functioning 68 Ford 4000 will easily pick up an 800 pound weight with a good boom pole. Note, "good."
Duly noted. "GOOD" boom pole...
Right now I'm hunting a good 16' trailer with no side rails (like a car hauler) to buy and transport implements. I found a 4 row planter for sale, for instance. It's too big for anything other than a car hauler-type trailer, and I have no idea how much it weighs.
/ New operator question (3 point hitch) #11
I assumed it would just sit on top of the side rails. I have abandoned that idea, though. Looking for a good 16' trailer with no side rails.
Do you have any trees you can put a come-a-long over a limb? You just have to lift the front of the mower and drive the trailer out from under it. Just be sure the rear tire has something to roll on.
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2001 Ford F-650 18ft Rollback Truck (A61573)
2001 Ford F-650...
Striker Slide in Spreader Box (A62679)
Striker Slide in...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2003 GRADALL XL330 HYDRAULIC EXCAVATOR (A59912)
2003 GRADALL XL330...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
