New Member JD 790
   / New Member JD 790 #1
MarcK
Dulzura, CA
JD 790
Hi from Sunny Southern California. I have a question but I am not sure where I should post my question, so I'll do it here. I have a JD 790 for which I bought a Brush-Hog mowing deck. The manufacturer of the deck suggests that the 3 point hitch be set to "Float" while mowing. How do I set the 3 point hitch to "Float" on my JD 790? Thank you in advance for your helpful advice.
   / New Member JD 790 #3
Float is just pushing the lever all the way down since the 3PH does NOT have downpressure.
   / New Member JD 790 #4
Welcome to TBN!!!
As far as float, your Bush Hog RFM (now, I am assuming you are referring to a Bush Hog brand finish mower, is that correct?) manual describes how to set it up.
If you don't have a manual, try here:
Manuals
If I'm correct about your mower being a Bush Hog brand finishing mower, read the attached .pdf, specifically Steps M and N and Figure 2-6.
BTW, you really should read your manual before using any powered equipment. The manual may answer questions you have (such as this one) and questions you haven't thought of yet.
BTW, the older (pre-2003) 790's did have a "float" adjustment on the tractor's lower links. This is shown in your tractor's operator's manual. My old 790 was a 2003 model and did not have this feature.
  • Bush Hog RFM Float.pdf
   / New Member JD 790 #5
Welcome to TBN :)
I moved your thread to the John Deere Owning/Operating Forum.
   / New Member JD 790 #6
Welcome to the forum from Oklahoma.
Ken
   / New Member JD 790
Thanks for the move
   / New Member JD 790
Roy, thank you for the information and for your sound advice.
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
1839 (A51248)
1839 (A51248)
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
