New loader bucket over curls, is jerky, and movements are erratic.
   / New loader bucket over curls, is jerky, and movements are erratic. #1
SouthernSky
Platinum Member
Deville, LA
2013 Kubota L3200DT
Just got my new Ansung 2545C-QB loader home today on my Kubota L3200DT, installed by the Kubota dealer who is also an Ansung dealer. This loader and bucket is supposed to be the same as the Kubota LA525 except for the decals -- not sure about that but okay. I knew I shouldn't have bought a tractor without a loader but didn't need one at the time.
So I pull it off my trailer and start curling the bucket. Sometimes it curls down, sometimes it curls up, sometimes it is real jerky, sometimes it curls down and up and around when I hold the control lever to the right. Definitely not the smooth action on my other Kubota tractor with a Woods loader.
What would cause a bucket to keep curling, like it hits the bottom edge when curled down and then goes back up on its own? Shouldn't it stop when it hits bottom? What would make it go both directions when the lever was pulled just to the right or just to the left?
Moving the joystick straight up or straight down raises and lowers the arms like it is supposed to. It is only the curling that seems to be really goofy.
Sure, I can take it back to the dealer (might have to) but they are 70 miles away, it is Saturday, and they have closed for the day.
Thanks in advance!
One follow-up -- If I move the joystick slowly right or left and not all the way to the stops, it works like it should. It's only when I move it all the way right or left to the stops that the curling gets erratic. Is there some sort of limiter I need to know about or adjust?
Is there a place I can post a small video so you can see what I'm talking about?
   / New loader bucket over curls, is jerky, and movements are erratic. #3
Try swapping the hose pairs between the bucket and the loader arms and see if it does the same or not. If it changes, it’s likely the joystick that’s giving you issues.
   / New loader bucket over curls, is jerky, and movements are erratic. #5
I believe that your lines are mixed up. The dump should operate with the joystick moved right (outwards), curl with the joystick moved left (inwards). That’s industry standard.
Try fixing the lines, verify everything, and try again?
Re: New loader bucket over curls, is jerky, and movements are erratic. SOLVED
I believe that your lines are mixed up. The dump should operate with the joystick moved right (outwards), curl with the joystick moved left (inwards). Thatç—´ industry standard.
Well, I値l be damned. I can稚 believe i didn稚 notice that before. I actually jumped on my old tractor next to it to confirm.
Wow! I feel dumb.
Youæ±*e my hero, Aquamoose. Damned if that didnt fix it right away. Thank you so much! i owe you.
And im going to have a little chat with the dealer tomorrow...
   / New loader bucket over curls, is jerky, and movements are erratic. #7
No problem at all. Hope the dealer will take care of you promptly!
10222 (A56858)
10222 (A56858)
24220 (A56859)
24220 (A56859)
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
2019 F150 (A56438)
2019 F150 (A56438)
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
