New L3200
/ New L3200 #1
Hammer Head
Lock Haven, PA
Kubota L3800 HST, Scag Tiger Cat
Nubie here,
Went to the local fair the other day and walked into the Kubota display. Spent some time with the sales staff, and ended up with a L3200Hydro with the 524 loader with 66" quick attach and B77 Hoe with 16" bucket.
I am a G.C. and purchased the tractor for general job site use, some footing excivation, stone handeling, moving lumber with forks and backfilling. General home use also.
The L3800 was a bit over my budget, do you think I made the correct choice?
/ New L3200 #2
Welcome and Congrats on the New Kubota. Did you get SS style forks?
/ New L3200 #3
You might want to get some front hydraulics later and get a narrow grapple like mine for trash clean up on the jobsite. It will make quick work of mixed trash/junk materiel's. My grapple is lightweight to make better use of your lifting ability. I am sure your tractor will serve you well both on the job and at home.
Everything Attachments Compact Utility Root Grapple 50"
/ New L3200 #4
Hammer Head,
Welcome and congratulations. You will find a thousand tasks for your tractor. You will find yourself needing other attachments as you learn ways to use your new tool. Choose them slowly. You should be able to find used implements. Feel free to ask many questions here.
For your use, there are very few tasks that the L3800 can do any better or faster. So good choice.
/ New L3200
Did not get them yet, have a friend with a set. Need to check to see if they will work.
/ New L3200
Good idea, I will look into it in the future.
/ New L3200 #8
Nice choice ...should serve you well.I worked construction for many years and have owned my own tractors for ten.Best "tool purchased "for the tractor was a thumb for the buck(and a tooth-bar) ,this would be very handy on a construction site.
/ New L3200 #9
Congrats on the purchase. Nice sized machine and not too big to be a pain in tight areas and trailering:thumbsup:
/ New L3200 #10
I made the same choice a month ago minus the hoe. Been pretty happy with it so far.
Dealer didn't have the gear to ballast the tires yet (New dealer, should finally have the stuff in a week or 2). I'm engineering 3 remotes for a top & tilt kit & spare remote already for my rear blades already (probably not an issue for you with the hoe unless you remove it a lot). And am planning on some work lights on the ROPS when I have free time.
Other than that I've been completely satisfied until I can afford a grand with a cab some day. No regrets saving $1k or whatever it was for 6 less HP. I'm running out of traction well before running out of power. More ballast soon might change that, but I doubt it.
/ New L3200
I like the size, I was looking at the B3300SU with same equipment but thought the extra size and weight would allow the hoe to work better.The loader has a bit additional capacity on the L3200
I don't have much use for the PTO other than a post hole digger, my thought for not going with the L3800.
I was also impressed with the turning Rad.
Some future equipment may be the thumb, grapple and angle plow for snow. Would I need additional hydro to run these implements or would the bucket tilt work the additional functions?
/ New L3200 #12
Get a manual thumb for your BH, it's only a couple of hundred bucks and it increases the versatility of the BH greatly.
/ New L3200 #13
Congrats! Very good tractor!
I like the extra HP of the L3800 for mowing, the manual PTO leaver (no electric, or cable) and the 2 stage clutch in the DT model. But other than that they are basically the same.
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2017 International 4300 Box Truck (A62613)
2017 International...
Landhonor Livestock Chute (A66408)
Landhonor...
12' x 24' Cattle Shelter (A66408)
12' x 24' Cattle...
HD Quick Attach Grapple (A66408)
HD Quick Attach...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
