eepete
Platinum Member
All this major stress cutting was with some help to both catch pieces being cut off so they didn't damage the tractor and to someone to call 911 if...
So what's pretty amazing is that the ROPS post was not bent, the paint wasn't even broken. That's a tough hunk of metal ! The interior of the cab has looked better, but notice that the frame and fender are intact. The switches and 3 PT hitch height lever, along with that entire plastic molding that hold them, need to be replaced but there is no structural damage- even the fender came through without a scratch! This is also why the remove had to be done carefully. If that post had shifted when de-constructing the building, it would have fallen into this area and taken out all the SCVs including the joystick and possibly bent the lower cab frame.
So two glass panes broken, two OK, guess that makes this a OS/CAB hybrid
So there it is free, ready to be towed to the dealer.
So on the plus side, in a month or so I get the thrill of having the same new tractor delivered twice, and I can stop worrying about getting that first scratch
Some minor lessons on living life here too. When things go wrong, take a deep breath and if no one is hurt and it can be fixed with money it's gonna be OK. Be sure your stuff is insured. And don't expect some outside entity to come swooping in and make it better, grab control of it. If I had not starting the extraction process and put a tarp on the tractor, the rain we had would have damaged the top section and interior of the cab. No good local business to do the de-construction, and doing it slowly prevents thousands of dollars of damage. Little bites and big cribbing kept the process manageable and safe. Volunteering in life gives you more than you put into it. Skills learned working with buildings in the fire department help me pull this off, and friends made helped at critical times. Plowing the neighbors driveway the day before meant they had the time to help me. It all comes around. Part of why this is a nice site is I know I'm preaching to the choir on this one.
The recovery of joints in my body should be done in a week or so...
Pete
Pete
