New JD450c owner
/ New JD450c owner #1
DrHolliday
statham ga
JD450c, case 310 backhoe
I am trying to put a JD450C back to working that has not been cranked in eight years, I have it running but it will not move, everything else works.
Hope to make it work without too much money.
DrHolliday
/ New JD450c owner #2
Welcome from Oklahoma. Good luck with your project.
Ken
/ New JD450c owner #5
Welcome Doc to TBN. A tractor is good medicine to get away from the rat race.
/ New JD450c owner #7
When you say "it will not move" what do you mean?
Does the engine lug down when you try to move it, but it won't move?
Does the engine not change speed when you try to move it?
Is it a manual transmission or a power-shift?
Oil in torque converter?
How old is the machine?
Btw, :welcome:
/ New JD450c owner #8
I don't think the 450C model was made with a powershift. I believe they only had a manual 4 speed with hydraulic reverser. The C's were made from about 1973-83.
/ New JD450c owner
Thanks Bob for the reply, I was pushing some dirt, with all systems go, then it stopped moving forward or reverce. I just ordered a OM from JD will have it Friday. Engine runs great and all other systems work. I did notice that a lot of fluid had leaked from around the left back finial drive.
Before I do anymore I will wait for the Manual. I think it is a 1979.
Thanks for any info.
DR
/ New JD450c owner #11
DR
It's obviously something that affects both tracks then. Check all oil levels.
/ New JD450c owner #12
DR
Do you have any feeling when pushing in the clutch? The main things common to both sides would be the engine clutch I wonder if something there let loose.
The high low reverse clutch is hydraulic, its possible the valve went bad or something in that system.
It could also be the transmission itself.
It's been a long time for me since I looked at one of these up close.
/ New JD450c owner #13
One more note:
If you go to Deere.com under parts you can look up parts with drawings of the assembly. I have found it very helpful in seeing how something goes together and/or help trouble shooting.
John Deere - Parts Catalog
/ New JD450c owner #14
I would try the forums at jdcrawlers.com, active board with lots of info.
/ New JD450c owner #16
I was a JD mechanic for many years. Does the left pedal (engine clutch) have the fell similar to a car clutch? If so, make sure you have enough transmission oil(checked running)/ under seat dipstick. If above are of, you kind of have to put some pressure guages in it to see if you have transmission pump pressure.
John Deere Planter (A62613)
John Deere Planter...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
Truck Tool Box (A65640)
Truck Tool Box...
65' Extension Cord Reel (A66408)
65' Extension Cord...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
