New JD 5055e
/ New JD 5055e #23
Rick,
Good choice. You won't regret having the full size tractor on 33 acres. The long wheel base is worth a lot for ride quality and picking up heavy objects. Plus the lift capacity (3000 pounds) will likely come in handy.
/ New JD 5055e #24
I looked at them this afternoon and you are correct, they are 16.9-28. Good eye you have there! :)
I thought they looked bigger than the ones on ours, it has 14.9-28's. And they were the upgraded size, the stock 13.6-28's would be pretty small on a tractor this size.
/ New JD 5055e
I did not order them, just got lucky I guess. That is how it sat on the dealer's lot. Must have been a special order at one time or another.
/ New JD 5055e #26
Congrats on your new "toy". I think you will very glad that you went with a little more tractor than you initially thought you needed. I know that I am.
/ New JD 5055e #27
I'm living across the pasture from you, over here in Burk. I have been considering this model for some haying and other hobby work. I think you got a good one!
/ New JD 5055e
Hey, neighbor. Welcome to TBN. Isn't this rain fantastic!
/ New JD 5055e #29
Great looking tractor Rick! Can never complain about 0% for 60 months :thumbsup:.
Just curious, did you check the difference in price between the exact same setup, just with the 5065e instead?
/ New JD 5055e
No, but I started out looking at the 5045. It was about $2000 less than the 55. I assume that the 55 is similarly priced compared to the 65. I probably would have been 10 hp happier with the 5065, but I had to put a stop to the escalator somehow. :D
/ New JD 5055e #31
You should have a lot of fun with it. I went with the 5065E and the dealer will deliver it this Friday ......by by Framtrac.
where in texas you located?
/ New JD 5055e #32
Houston
/ New JD 5055e #33
Here is our new 5065E that was delivered last Friday. Boy did I have fun over the weekend!
/ New JD 5055e
Ooooh! I really like that grapple. I have around 20 acres of grubbed mesquite that I could make short work of with that baby!
What made you choose the R4 industrial tires over the R1 ag tires?
/ New JD 5055e #35
I am getting ready to pull the trigger on a JD 5065E. Some guys have told I have to have 4WD. I have been getting by w/ an old Ford 4000, and do not thing I need the 4WD. Any opinions?
Michael
My first tractor purchase was a 2WD JD 5105. I later added a FEL to it. Loved the tractor, but lacked traction. Considered trying to upgrade rear tires from 14.9-28 to 16.9-28, adding weights and removing water to add RimGuard. In the end I traded it in on a 4WD JD 5303 with FEL. I initially assumed I could get similar performance out of the JD 5105 as I was used to with our Ford 4000. The difference in the 4WD vs 2WD is amazingly different. You can get the best use of the horsepower with the 4WD. I also recommend going with the 16.9-28 rear tires and the 4WD. The JD 5303 gives similiar performance to the Ford 4000 and is basically the same as the JD 5065E. Our Ford 4000 is a later model with 16.9-30 rear tires and I believe comparing them both in 2WD the Ford 4000 may out pull the new JD 5303.
HLA Attachments Loader Forks (A64119)
HLA Attachments...
2022 EZ-GO ELITE...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
2023 Case TV450B (A62177)
2023 Case TV450B...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
