New JD 5055e
/ New JD 5055e #23
Rick,
Good choice. You won't regret having the full size tractor on 33 acres. The long wheel base is worth a lot for ride quality and picking up heavy objects. Plus the lift capacity (3000 pounds) will likely come in handy.
/ New JD 5055e #24
I looked at them this afternoon and you are correct, they are 16.9-28. Good eye you have there! :)
I thought they looked bigger than the ones on ours, it has 14.9-28's. And they were the upgraded size, the stock 13.6-28's would be pretty small on a tractor this size.
/ New JD 5055e
I did not order them, just got lucky I guess. That is how it sat on the dealer's lot. Must have been a special order at one time or another.
/ New JD 5055e #26
Congrats on your new "toy". I think you will very glad that you went with a little more tractor than you initially thought you needed. I know that I am.
/ New JD 5055e #27
I'm living across the pasture from you, over here in Burk. I have been considering this model for some haying and other hobby work. I think you got a good one!
/ New JD 5055e
Hey, neighbor. Welcome to TBN. Isn't this rain fantastic!
/ New JD 5055e #29
Great looking tractor Rick! Can never complain about 0% for 60 months :thumbsup:.
Just curious, did you check the difference in price between the exact same setup, just with the 5065e instead?
/ New JD 5055e
No, but I started out looking at the 5045. It was about $2000 less than the 55. I assume that the 55 is similarly priced compared to the 65. I probably would have been 10 hp happier with the 5065, but I had to put a stop to the escalator somehow. :D
/ New JD 5055e #31
You should have a lot of fun with it. I went with the 5065E and the dealer will deliver it this Friday ......by by Framtrac.
where in texas you located?
/ New JD 5055e #32
Houston
/ New JD 5055e #33
Here is our new 5065E that was delivered last Friday. Boy did I have fun over the weekend!
/ New JD 5055e
Ooooh! I really like that grapple. I have around 20 acres of grubbed mesquite that I could make short work of with that baby!
What made you choose the R4 industrial tires over the R1 ag tires?
/ New JD 5055e #35
I am getting ready to pull the trigger on a JD 5065E. Some guys have told I have to have 4WD. I have been getting by w/ an old Ford 4000, and do not thing I need the 4WD. Any opinions?
Michael
My first tractor purchase was a 2WD JD 5105. I later added a FEL to it. Loved the tractor, but lacked traction. Considered trying to upgrade rear tires from 14.9-28 to 16.9-28, adding weights and removing water to add RimGuard. In the end I traded it in on a 4WD JD 5303 with FEL. I initially assumed I could get similar performance out of the JD 5105 as I was used to with our Ford 4000. The difference in the 4WD vs 2WD is amazingly different. You can get the best use of the horsepower with the 4WD. I also recommend going with the 16.9-28 rear tires and the 4WD. The JD 5303 gives similiar performance to the Ford 4000 and is basically the same as the JD 5065E. Our Ford 4000 is a later model with 16.9-30 rear tires and I believe comparing them both in 2WD the Ford 4000 may out pull the new JD 5303.
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
UNVERFERTH PERFECTA II 18' FIELD CULTIVATOR (A63291)
UNVERFERTH...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2022 EZ-GO ELITE...
