Loader New jd 4520 loader flexing
/ New jd 4520 loader flexing #1
dmrp6510
Dayton, OH
John Deere 4520 Cab
We have a new Jd 4520 that the loader is flexing left to right when you push into dirt enough to notice the loader arms aren't straight once you back up and raise the bucket it seems to go back straight I think there's air in the one side of the loader arm's any thoughts.
/ New jd 4520 loader flexing #2
First I would double check the loader frame to make sure one side is not loose or disconnected. Next I would make sure the quick connect hydraulic line connections are fully seated by disconnecting (make sure there is no load on them by lowereing the bucket and releiveing all pressure) and reconnecting them.
Have you tried cycling the loader boom cylinders the full stroke to get the air out under no load? When I replaced a bucket cylinder hose, it took a lot of cycles to get the air out. Seemed like a dozen or more before it was working evenly with the other one.
Columbia Vise (A65640)
Gravely Walk Behind Tractor (A65640)
Gravely Walk...
2012 FORD F-550 CAB AND CHASSIS(INOPERABLE) (A65643)
2012 FORD F-550...
2018 CATERPILLAR CB10 DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
1985 Ford F-250 Pickup Truck (A62613)
1985 Ford F-250...
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
