New JD 3038e No speedometer
/ New JD 3038e No speedometer #1
darrellbarnes
Eastern Washington
YM2310D, John Deere 3038e
Fresh off the lot 3038e. From all indications in the owner's manual there should be a speedomter on this thing. Anybody know for certain if it's a. not available. b. optional c. not working.
I'd call the dealer but the salesman told me it didn't have a turbo so I'm not gonna start with him.
Pasture spraying is goint to take some ingenuity if I can't peg a repeatable speed.
Thanks
/ New JD 3038e No speedometer #2
It looks like the 3038E has a techometer but no speedometer. I'm not aware of any JD CUT that has a speedometer.
/ New JD 3038e No speedometer #3
The 4x20 series has a dial face tach and digital hourmeter like shown; however, the hour meter toggles itself to spedometer while you are moving then back to tach when you stop - or you can press the button and toggle manually as well. I don't think the 3038 has that feature.
Regardless, you can calibrate your rig using a set distance and stop watch. That is what we did when I was a kid. Even if a tractor has a speedo it isn't usually super accurate and my Dad would set use the stopwatch anyway.
/ New JD 3038e No speedometer #4
There are often charts relating speed by gear by rpm. Not so easy if hydrostat tranny.
Deere manual linked here.
Specifications
But there are add-on ground speed sensors that are probably the best way to go. Not so cheap.
Other than that, measure out a distance, travel it with the tach at a certain rpm and cruise set and determine the mph using a clock or stop watch. Can be done (as Dusty said).
From the online owners manual................
LV16683
LV16683-UN-21FEB13
A - Left Turn Signal/Warning Flasher Indicator Light -Flashes when turn signal switch is moved to left turn position, or when light switch is turned to warning flasher lights ON or road position.
B - Tachometer - Shows engine speed. Engine speed is shown in 100s. Example: If indicator is pointing at 20 (20
L - Information Display - Displays speedometer, hour meter, PTO hour, PTO speed, regen information and diagnostic trouble codes (if active).
/ New JD 3038e No speedometer #6
My tractor as well has a tach, but no speedometer. Because I was interested in knowing how fast I was going I downloaded the Ulysse Speedometer app. I have tested in both my car and truck. The app matches them both in measuring speed and distance. Here is a link if you want to look at it.
https://play.google.com/store/apps/details?id=com.binarytoys.speedometer
/ New JD 3038e No speedometer #7
On my Kubota (wrong brand, I know), the digital display serves various functions. You have to toggle through them to select the one you want. See if your dash has a button labeled "display mode" or something similar.
"See if your dash has a button labeled "display mode" or something similar." It does and works. Owners manual shows and discusses the speedometer but it must be for a higher end.
That might be the plan. With my Yanmar I can pick a gear, RPM and time it for repeatability.
Thanks for the suggestions.
/ New JD 3038e No speedometer #9
On my JD 3320 the speedometer is as dusty3030 says about the 4x20 series. The LCD is an hour meter until there is movement, then it becomes a speedometer. It works in forward or reverse.
/ New JD 3038e No speedometer #10
I don't recall my 3032-e having speed readout [2013 model].
There are several items that do not exist on the "E" models.
/ New JD 3038e No speedometer #11
What is the serial number of your 3038E? Is your engine a Yanmar 3TNV84T or a Yanmar 3TNV86CT-NJT? It looks like there are two different instrument panels. One includes a LCD information display that includes a speedometer function and the other does not.
/ New JD 3038e No speedometer #13
No speedo for this tractor but Google "calc-an-acre" from micro-trak, as another alternative. A little expensive but an impressive little tool.
2008 Jeep Wrangler Unlimited 4X4 SUV (A59231)
2008 Jeep Wrangler...
PALLET OF (3) CABINETS (A60432)
PALLET OF (3)...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
JLG 600 AJ SKYPOWER BOOM LIFT (A60429)
JLG 600 AJ...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
