New inexpensive trimode welder
   / New inexpensive trimode welder
Mark, thank you. That looks like a very nice unit and well out of my price range.
My understanding is the primary use for TIG is aluminum. Please correct that if needed.
Since I have zero desire to weld in aluminum, perhaps I should have asked about the best inexpensive dual mode, meaning
stick and MIG. Why pay for TIG if I'm never going to use it.
spool feeder sounds good but not if heavy or clumsy. Stick is pretty simple.
I'm sorry I don't know enough to ask good questions here.
   / New inexpensive trimode welder #33
I previously had an Everlast stick/? that I was very happy with, never got beyond stick.
Farm sold, only need light duty but would like flexibility.
With a 400 dollar budget, what else should I be looking at?
No aluminum. Want something easier and less skill demanding than rods. Which I barely mastered.
Ready for new machine and different way of welding steel.
may I assume I want something with a spool of wire inside?
Is there an Everlast equivalent to this:
I remember buying welding rods these folks made
thanks Drew
It's real easy if you were happy with your Everlast go get a Everlast mig. I am also very happy with my Everlast Mig and TIG welders Now retired welder my whole life. Second you will not find any made in America welder (Lincoln, Miller Hobart) etc for under about $3000. They can not compete with offshore so they get their less expensive stuff built offshore
   / New inexpensive trimode welder #34
Very generally....
Tig will finely weld aluminum, but requires more skill as a welder. I would describe Tig as precision welding of materials that are very difficult to successfully weld with other methods.
Mig is thought of as easier than stick because the welding machine feeds the wire.
Depending on the welding capacity of the mig welder, the size and type of wire used, a mig welder can be set up to weld anything from auto body sheet metal up to fairly thick metal. If you set up to weld thin sheet metal, that particular wire and shielding gas may not be suited to thick metal. You have to match your welding wire size, flux or shielding gas, to match the thickness and type of welding you expect to weld most often. For example, .30 flux will weld a wide range of metal thickness, but wouldn't be my first choice for welding a thin sheet of metal.
FWIW, some mig wire welders can also weld aluminum. The issue is aluminum wire is soft and doesn't like being pushed through a long mig cable. It tends to jam. The purpose of the spool gun is to put the aluminum wire spool near the tip of the welding gun to avoid jams.
Stick is easier to change rods to suit a particular welding situation than it to change out the wire roll on a mig.
Stick welding thin sheet metal is more of a challenge than welding thin metal with either tig or a properly setup mig welder.
What you should buy partly depends on what you intend to weld.
   / New inexpensive trimode welder #35
well now this looks interesting if I really can ditch stick:
says made in USA, 550 entry point. Not bad. Costs twice as much as imported because we pay our people better. I'm ok with that.
lots of 300 dollar alternatives on Amazon, keeping in mind California's good experience. I've bought lots of HF stuff too, not usually what I would ever consider "good tools".
But if I need three different phillips head screwdrivers, they all don't have to be the good stuff. My favorite tool, the most used one, now I just might spend little more on that.
I actually just bought this unit a few weeks ago. I had a Millermatic 185 that was a very nice welder. I really wanted a plasma cutter and a tig welder as well, so I decided to sell the Millermatic and put the money towards the Mig180 and CT520DP (unfortunately not in stock yet). I actually still had money left over after that, so I bought an argon tank. The only reason I got the Primeweld was that in my research for an inexpensive alternative to the blue and red machines many on the welding forums recommended Primeweld. They are based in NJ and they are very customer service focused. The units come with a hassle-free 3 year warranty.
So far I've only used it once. I like that it has actual values for voltage and wire speed unlike the Millermatic, but it will take a little bit for me to get used to that (It comes with a large sheet with what voltage/speed for what material and thickness). The Millermatic had arbitrary numbers to indicate voltage and wire speed and I got used to those settings. I also like that you can use 10lb spools in it, as that is what I have.
It does come with a stick welding stinger, so you can still do stick with it. You can do flux core (gasless), which for most applications under 1/4" (and some applications over 1/4") it replaces stick. It comes with the spool gun for doing aluminum. My Millermatic had a spool gun as well, but I never used it. I just never had a need to weld aluminum. You can also do the MIG with gas which produces a nice clean weld (no slag).
A side note about the Millermatic, I bought it 7 years ago for $850, and sold it 3 weeks ago for $1300 with many people contacting me. So for less than what I sold a 25 year old single process blue machine for I bought 2 machines that can do 4 processes together. And they will take up the same amount of space together than the old blue machine. The MIG180 is far lighter and more portable than the Millermatic 185 with similar specs. That's where inverter technology beats out the old transformer technology.
   / New inexpensive trimode welder #36
Lincoln AC/ DC 225 lasted me 30 years; you must have a DC welder.
   / New inexpensive trimode welder #37
Very generally....
Have to agree with that but sounds like you got the primeweld on your mind. If you get it use it quickly and use it a lot right off the getgo in case your not satisfied with it you can return it. Good luck 🤞
thanks for all this input, I'm absorbing.
   / New inexpensive trimode welder #39
Something in the 140 range should suit what you want and price range... I have some of the Titanium offerings from harbor freight and they're treating me well even though I have the 170 and 200 but still, I've beat the everliving snot out of the 170 since I basically stole it (open box sidewalk sale on Sunday back when that meant half price, $125 out the door...)... I have no doubt the 140 offerings from Titanium or Everlast would do similar as I don't push the limits that hard, I'm usually running off of a 15A 110V circuit or a 4kw generator or something dumb with flux core, but have wicked it up on 220V burning in 1/4" plate real nice too... If you're stuck with no gas that's basically limiting to flux core which isn't near as bad as what anyone says, it's just not as pretty... it's more like a glue gun with 6011 rod... takes some getting used to but I have no complaints... in the next couple months I will be upgrading to welding with gas on my 200, I have a spool gun for it and hope to TIG some stainless tubing and gear up to do some aluminum welding on my boat...
   / New inexpensive trimode welder #40
There's a big difference in the Titanium and the Everlast. Starting with warranty. And ending with design and quality of internals.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 UTILITY 48FT REEFER TRAILER (A59575)
2015 UTILITY 48FT...
2013 John Deere 5075E (A57148)
2013 John Deere...
207269 (A52708)
207269 (A52708)
2025 Yakta YXR610 Zero Turn Lawnmower (A57453)
2025 Yakta YXR610...
Hose Reel (A55787)
Hose Reel (A55787)
