New Home HVAC System
   / New Home HVAC System #11
Mini splits are amazing. Both heating and cooling. Look at the performance numbers, they are real. Then look at the losses of your average installed ductwork systems. That alone will make up your mind. They have become the standard up here in Maine and the HVAC contractor's norm. Pricing a m/s setup for my daughter's home in the mid Atlantic region, those guys are still pushing the basically antiquated traditional ducted h/p with a huge high amperage and very expensive to run resistance heat for backup and were unfamiliar to say the least with a ductless mini split system and therefore out of their comfort zone and very expensive for the install.
With any luck, you'll find a contractor that is aware of this relatively newer (to the US) technology and is familiar with its highly reduced labor for installation and you get a good bid from them.
   / New Home HVAC System #12
We have mini-split system and love it. Our house is small, it costs about $1/day for heating in the winter, until temps get below 20dF then we go to the wood stove. Ours is one of the older Mitsubishi Mini-splits that the efficiency drops off fast below 20dF. New ones are good to below -5dF. In the summer it costs about $0.50/day for cooling. If I was building new, Geothermal would be my first choice, mini splits second, central air heat-pump last. Biggest issue with Mini splits is the WAF of the interior units. At least one of the mini split makers has units that recess into the ceiling and don't look any different than a central air duct.
   / New Home HVAC System #13
We renovated our 2,500sqft clinic and decided to rip out the old electric forced air system with fiberglass ducting and replace it with a Mitsubishi Mini Split w/ hyper heat here in northern Wisconsin. We have 8 in-ceiling cassettes, a junction box, and two outside condensers. We are very happy with our decision. Our heating costs were cut by 60% in winter and cooling costs are next to nothing. Independent room temperature control is great. When I know there will be an infant on the schedule or some of the older women I can turn just that room up. It’s also very nice to feel the heat or cold coming out of the indoor unit and not hearing any noise with it. We were concerned about heating capacity, but even with the -0 temps we’ve had this week there have been no problems maintaining room temperatures. The system wasn’t exactly cheap at around $35k installed but we’ve already saved around $7k in heating and cooling costs in the past year and a half. We plan to use the same thing in the home we’re building this year and expect that system to be far less costly since there was a significant amount of labor associated with removing old equipment and working on a remodel. There was also about $8k worth of costs on government mandated add-ons since it’s a commercial property.
   / New Home HVAC System #14
Actually mini splits can exceed the efficiency of a closed loop geothermal system, and get close to an open loop. In various buildings I have an open loop geothermal, air to air heat pump with propane furnace, and mini splits. If I were to build a new house, I’m nearly certain that I would use multiple mini splits.
   / New Home HVAC System #15
Instead of using mini split, you could use a VRF unit and run to multi heads. You can run longer line set with VRF than mini split.
only issue going with one unit is, If the unit goes down, you have nothing.
Multiple mini ODU's would prevent you from losing everything should the single unit go down
Had I built this home new. I would have installed VRF with multi heads /zones.
Since my home was already built and had a conventional ducted system. I installed a VRF, with a matching AH.
In most cases, people with a normal HP will have to have supplemental heat. Not so much with these units. I think mine is rated at -20 deg . I have never had an issue with heating my home.
Another thing is, a conventional unit will either be all on or all off. When On, it's at 60 HZ.. Not with these units. Mine idles along most times around 18-20 HZ. and will ramp up when xtra heat, or cooling is needed.
Energy requirements are increasing, and pushing the conventional units out.
   / New Home HVAC System #16
Biggest problems with mini-splits are poor air filtration and lack of outdoor air input capability. If you have allergy's or asthma/opd you really need the electronic air cleaning and fresh air intake capable with central fan systems. With mini-splits the coils run colder so they lower humidity with all re-circulated air to below the comfort/healthy level of around 50%.
Ron
   / New Home HVAC System #17
We have been using three Mitsubishi minisplits with heat pumps for 12 years now and are still doing good. We are using them at our rural Texas ranch, which is completely off the grid. Entire lithium battery bank provides power and is fully dependent on Solar and Wind for recharge. Each minisplit provides AC or Heat to specific parts of the ranch house, and we typically run only one minisplit a time. For example, at night there is no need to cool the living room while we are sleeping at night in the bedroom. This greatly reduces our total electrical power needs over what a Central Air System would need.
   / New Home HVAC System #18
We are in the planning stages of building a new house. My original thought was to have a standard central air and heat ducted system using heat pump with propane backup. We also will have non vented fireplace with gas logs for supplemental or backup heat if the power goes out.
In talking to a friend who retired from the HVAC world he suggested looking at a Mitsubishi Multi Zone Mini Split System. Multi-Zone Cooling and Heating Outdoor Units | Mitsubishi Electric
Are any of you guys using a system like this in your house or have any knowledge of it? I have studied it some and it certainly looks interesting. I like the idea of each room/area temperature being controlled independently. I also like the idea of no duct work as well.
I'm finishing my new house and garage/shop/studio apt. right now. I put in a Trane heat pump for the house, 1400 sf rancher. That will be more than enough but i might get a pellet stove just cause i love them!
My shop is on one end of the garage and the apt is on the other, both about 400 sf. 2 car parking in the middle. I put in the mini splits you refer to, 1 for the apt and 1 for the shop.
$6K for 2 mini splits. I hope they are the solution, i didn't want window mounted units.
   / New Home HVAC System #19
We had a single zone Fujitsu ductless heating/air conditioning unit installed in our living room last spring and have nothing but positive things to say about it. We ran the a/c all summer and our electric bill was significantly lower than the bills we had running a 12,000btu window unit, and the unit was almost silent. Maybe a $10-$15 more monthly versus not running an a/c.
   / New Home HVAC System #20
you don't have to get wall mount cassettes. They make ceiling cassettes
John Deere 3038E (A50120)
John Deere 3038E...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2019 Caterpillar DP35N Forklift (A51691)
2019 Caterpillar...
2017 JLG 1932R 19FT Scissor Lift (A50322)
2017 JLG 1932R...
2023 Kubota L2501D 25HP 4WD Utility Loader Tractor (A50322)
2023 Kubota L2501D...
2012 Hyundai Elantra Sedan (A50324)
2012 Hyundai...
