New Guy First Tractor
/ New Guy First Tractor #21
Have you entered bare tractor weights into your spreadsheet for all the tractors you are considering?
Bare tractor weight will allow apples-to-apples comparisons better than any other single specification.
Bare tractor weight is an easy number to research in sales brochures and tractor web sites.
In the compact tractor category it takes a 50% increase in bare tractor weight from one model to another before the operator notices a significant 'real world' increase in tractor capability.
I have those numbers. I have been looking at weight, wheelbase, length and width. Kubota seems to be one of the lighter tractors with Bobcat and Branson being on the heavy side.
/ New Guy First Tractor #23
3 vs 2 speed hst : Most agree that 2 speed hst transmissions will be worked 90% of the time in low, and just drive to the next task in high. I definitely prefer 3
I don't pay for the name. I pay for a quality tractor, good dealer support, service, and parts availability.
Have fun shopping!
Please post the polls you got those numbers from? I call the 90 percent plain bull 覧覧!
Absolutely no one I know including myself that operates in low 90 percent of the time while working a 2 range HST!
If that was actually the case I would have sold any of them I ever owned after the first days use! I would also venture to say most of my friends would have done so also. In honesty I think my 2 speed has been in low 2 times in the past 4 years. High covers most of my needs but is a bit lacking on the hills. It is however better and more effective to be patient in high range 90% of the time by just using a light foot on the pedal than it is to downshift. Shifting to low range usually only means you can use all of the low range which is going to be slower than using the low end of high range.
This is not to say that all 2 range tractors are created equal and it痴 also not to say all 3 range tractors are great as I have found and experienced some from all camps that just simply don稚 work well overall.
The more I think about those I know who are in low too much and complained before they sold thier tractor and purchased a replacement are now on bigger machines most with 3 ranges and actually ended up shifting more from med to low with almost no use of high range. Note they went to bigger tractors and overall use the same basic gears (1st and 2nd) and the same average speed of travel. I would assume if they had opted for a larger machine also with a 2 range they would be just as happy with it as they are with thier newer 3 range.
There are exceptions to this but most seem to be with bigger properties and more varied usage.
If you pay more for a kubota or JD than an other brand then you have paid for the name along with a false perception of quality! Owning them myself neither brand has shown me better quality than the next, nor have I been disappointed with dealer service by any brand. BUT the 2 that stand out as being superior in quality, defined as not needing the dealership for anything in a given timeframe are that old NH Ford I had years ago and my Kioti.
The quality of all brands of tractors out there today is actually mind blowing.
After looking and looking i decided on the Kioti CX2510H. Looked at it the other day and picked it up today. It has a front end loader and the new R-14 tires. I had them load the rear tires for ballast. I was moving towards the Yanmar 424 but it only has 9.9in of ground clearance. This tractor has 13.4. After discounting the Yanmar i really wanted to lean towards the Kubota 2601 but it lost in most every category. It is 600lb less and a drop from 87cc to 68cc in engine size. Ground clearance was an half an inch less, it did have a 3 speed transmission and mid PTO. Kioti mid PTO is a add on option. Now to learn how to use it. The book is not very well written so i will be asking questions in the Operator section.
/ New Guy First Tractor #25
Congratulations on your purchase.
Is there any particular reason why you didn't go for the CK2610? - just asking.
/ New Guy First Tractor #26
Congrats on the new tractor!
I did look at a new one. It was a very nice machine. I sat on it and just was not comfortable, i am only 5'7" and that tractor does not come with tilt steering.
The steering wheel was to far forward pointing almost straight up and was not a good fit. Had it come with tilt, i would have bought it.
/ New Guy First Tractor #28
Congrats on your new tractor.
/ New Guy First Tractor #29
Congrats on your purchase - I no nothing about this model, make sure you give us an update - I think the R-14's are going to be the go to for a lot of us, looking forward to your opinion on those as well.......
/ New Guy First Tractor #30
Congrats on the new tractor! I don't think you will be disappointed.... they are great workhorses
/ New Guy First Tractor #31
The cutoff for the expense of pollution control is 26 hp, so if that's your size, there will be lots of options. I have a 15 year old 26 hp machine, and am thinking of going bigger, but the problem I run across is that the tractors that have what I want, are too big for my implements. The biggest tractor I can sensibly trade in for would be the Kubota L3901, which has a loader rated at only 100 pounds more than mine to full height. One thing to think about is if you ever want to run a PTO chipper or chipper-shredder. The 26 hp tractors are limited on that score. I bought a used 5" chipper shredder and it's right at the top of what my tractor can handle. If I were considering a 26 hp Kubota, I'd be definitely looking at the larger one. You might even line the L2501, though for a tractor its size, it really lacks pto power..
Just want to thank everyone for all the good advice. Had my Kioti CX2510 for a few days now and i have been driving it around out back, breaking it in so when warm weather hits, it will be ready to work. It just fits some of the tight corners i have thru the woods so any bigger would have been just a little to much, so i am very happy so far. Driving on snow and ice, i still need the 4x4 even with the new R-14 tires as the loader weight leaves the back tires a little light. Next thing is some suitcase weights. Just need to figure out how much weight i will need.
/ New Guy First Tractor #33
Enjoyed your post and all the great input from everyone. I'm in a similar market with similar property. I was just eye-balling a Kioti last weekend. They do look pretty nice. Send me your speadsheet! LOL
Sorry i tossed the spreadsheet. I do like my Kioti, good luck. Start a new post and we will help you with filling in the spreadsheet with the important fields.
/ New Guy First Tractor #35
You can get a weight bar and weights or you can get a rear implement. I have a grading scraper that is really heavy, but also kind of Big. The rear blade is lighter and shorter, but wider. They work nicely as weight and even better as implements.
I am surprised that with loaded tires and an empty bucket you feel you need more weight. My B2620 is feels fine without anything back there.
Empty bucket it is fine, i do notice on snow more weight would help but the weights will be for a loaded bucket. I made one out of conctrete, came out to 400lb and is compact so moving around it won't take up any more space.
/ New Guy First Tractor #37
This thread helped me with my purchase on Saturday of a Massey 1723E. I love it--and am looking for weights like right now. I can't say my dealer 4 hours from me with a good price gave me any training at all--he handed me the manual and asked if I needed help loading it. It was a lot less money but still, some quality training for a first timer would have been very helpful before I scared myself the next day twice in 2 hours.
I plan on reading a lot here--I've been on gun, car, bike and boat forums before, always very helpful.
/ New Guy First Tractor #38
Grats on your new machine ProfJeff. Shame the dealer didn't take the time to show you the ropes. I'm in a similar situation with a little GC (first tractor) coming next week.
I would love to learn some lessons the easy way - do you mind sharing how you scared yourself? How do you feel about the little GC so far?
/ New Guy First Tractor #39
take a look at the Yanmar YT 235 Yanmar makes the whole tractor and with a 10 year warranty and its make for your confort! confy seat and the are rest is adjustable so you can adjust it so you hand sits on the bucket control
willy
The Yanmar is nice but has little ground clearance. One thing to remember about the long Yanmar warranty is you must take it to the dealer every year and pay them what ever they want to charge for an inspection/adjustments to maintain the warranty.
Metal Texaco Statue (A64127)
Metal Texaco...
2007 Great Dane 53' Reefer Trailer (A64127)
2007 Great Dane...
Hedge Posts (A65640)
2022 John Deere 5055E (A64126)
2022 John Deere...
2016 John Deere 6155R (A64126)
2016 John Deere...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
