New Green 2305
/ New Green 2305 #41
Great picture Mayor! Keep those pictures coming. You sure do have a beautiful place. I talked to my dealer yesterday and he told me that my 2305 is in but the 260 hoe, mmm and front end loader will not be in until April 13th!
Anyways another 2 weeks.(Sounds like that movie The Money Pit)
Your right. These pictures get me through the day better. Thanks
BIGWES
/ New Green 2305
Man, it won't be long and you will be digging a trench around the house. Don't forget the draw bridge.
/ New Green 2305
Had the day off and picked up a set of gator style blades from my JD dealer. Everything I read said they work great. I am coming from a JD LX280 with a bagger and hope to get a good resuilt with the new blades. I still think I will have to get the mulch kit but who knows. The blades were $55.00 for 3. Will try them out as soon as the weather lets up.
/ New Green 2305 #44
Let me know how those new blades work. Yesterday I had my Honda riding mower jacked up because I was trying to get all the dirt and junk off the mower deck. When doing this, I realized how much more easy it will be to simply detach the mower on the Deere and clean it up. I figure hopefully by next week I will have my 2305 in. I look forward to mowing with the 54 mmm over the Honda 38" cut!
BIGWES
/ New Green 2305 #45
Very nice! I remember when mine was that clean...lasted about 2 hours :D But for what its worth, here's my 2305 after a long day of plowing.
/ New Green 2305 #46
What is attached to the go pedals? :confused:
/ New Green 2305 #47
snoiger01, I would pull your FEL hydro hoses up over the loader mount to get rid of that slack hanging down. It would suck if you snagged a line on something.
It looks like you have the pedals rigged up for manual manipulation. Is that right?
/ New Green 2305 #48
Ahh, so ya'll noticed the pedal addition...well I'm a parapeligic and have to use those to work the pedals since I can't use my legs. Works great, except when they get caught on the FEL control, which isn't often. If I'm mowing I just turn the control lock knob to keep the FEL from moving.
Now getting on the tractor from the wheelchair seated position is ALOT of fun...but sure impresses the neighbors :p
Now if I could just figure out some way to carry the wheelchair with me. Nothing worse than getting several hundred yards away from the chair and need to adjust a plow or something, or worse yet getting stuck and having to do the "two cheek shuffle" across the pasture. I've experimented with a few options but only managed to bend a wheelchair rim...and those things aren't cheap. So, if any of ya'll have any ideas I'd sure like to hear them.
Oh and about the re-routing the hoses....good idea. They came from the dealer that way and I guess I never really noticed how low they hang. My property is flat as a pancake and so far I haven't snagged them...but I'd rather be safe than sorry.
/ New Green 2305 #49
WOW, you are an inspiration to use all! After growing up with a wheelchair bound Mother (she had MS) I can appreciate your determination.
How about thinking of a way to pick up the wheelchair with the loader? Maybe take the bucket off and pick it up right from the QA plates somehow?
/ New Green 2305 #50
Thanks KennyD,
I don't look at it as "inspiration"....just doin what I gotta do. Anyway, I've experimented with putting a hook on the side of the bucket...with miserable results....I was able to pick the chair up, but putting it down was a little less than desirable. I do use the bucket quite a bit...even to open and close pasture gates, so taking the bucket off probably wouldn't work. I'm thinking I could build a simple something out of wood (no welder) that I could just slide on the bucket. Maybe a small forklift type contraption. I could then pull up to it, slide it on the bucket, pick up the chair and go. then just slide it off by lowering to ground and backing up. Chair weighs about 23 pounds, so it doesn't have to be a super-duper strong contraption. I have several other projects lined up, but when I get around to it I'll keep ya'll posted. Until then I'll keep relying on my 3 kids to bring my chair...oh and they think its REAL funny to pretend they can't hear Daddy and go in the house and leave me stranded.
/ New Green 2305 #51
Do you have a ballast box? Maybe you could configure something on the back of the that and then use the 3PH to lift the chair up and hold it. Kind of like a wheelchair i-Match!
/ New Green 2305 #52
Good idea Loogie,
I have been so focused on the FEL that I forgot the tractor has two ends. I do have ballast box and something like you mention would be easy enough. And if I can keep it a simple addition, then I could make one of "it" for each implement...plows, mower, etc. so no matter which one I happen to have hooked up at the time, I can take the chair too. And since I use the FEL to open and close gates, that would keep the chair from getting tangled up in the gate.
/ New Green 2305
I think your on the right path with the three point. Maybe a mount on the ROPS would work also.
/ New Green 2305 #55
snoiger01, my knees are in bad shape (arthritis) and at times, I have trouble getting up onto the tractor and I complain under my breath about it. However, after reading about your courage in the face of adversity, I think I'll quit complaining. I can't imagine going through what you must have endured. Like Kenny said, you are truly an inspiration. God bless you.
/ New Green 2305 #56
Thanks Gary,
God has already blessed me in more ways than I deserve. I was hit by a car when I was 7 yrs old, which actually made it easier to adjust. I'm 38 now and even to do this day, I can look around and see someone in much worse shape than me. And as ironic as this may sound, I can't even begin to imagine living with the pain of arthritis. Guess thats the good thing about being paralyzed from the chest down....sorta limits the amount of aches and pains you get :D
/ New Green 2305
This is a sweet tactor. It ran all day and used 4 gals of fuel. Moved 5 ton of rock, put in a trench, put 40 yards of mulch down, and cut/stripe 1 1/2 acres of lawn. Now that was just Sat. Sun I chased a little white ball around in the sunshine. What a time saver. Last year it took two days (16 hours) just to move the mulch. Well I guess it paid for it's self for the next two months. Still waiting for some topsoil and fill so I can move my storage shed. Having problems getting the tractor in and out do to some trees. What did you guys do this weekend??? Oh I almost forgot. The only thing that is sore is my joystick arm!!!!!
/ New Green 2305 #58
maybe if you ask, they will let you put some water or sand traps in!!!!:D
/ New Green 2305
Worked on moving my shed to another location in the yard. This little tractor makes quick work of this project. The stone is on order and then I will pack it down by driving on the area with the tractor/weight box/full bucket. The soil has a lot of clay in it. Will also add 5 in of 2B stone to the top. The shed will be on the left side. The area is 16x20. The shed is 12x14. This gives me a nice little driveway area. Do you think I need compactor?
2017 Chevrolet Express 3500 14FT Box Truck (A61573)
2017 Chevrolet...
Farmall Cub Tractor (A62613)
Farmall Cub...
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A61573)
2015 Hyundai...
2007 Cadillac DTS Sedan (A61574)
2007 Cadillac DTS...
159116 (A60430)
159116 (A60430)
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
