New garage time!
   / New garage time! #631
Being able to tie the first floor to the second floor with your siding is really important.
If you leave it sticking out a quarter of an inch on each side, you could daddo out a quarter inch out of 3/4 inch plywood, and probably be fine.
Or you could cut 3/4 of an inch off of each joist. that should give you enough material to put the screws back in and still have your strength.
   / New garage time! #632
Theoretically, yes. The sheathing is where your wall shear strength comes from. Having a seam straight across the entire side is not ideal, but I am not aware of any code that would prevent a seam but then I am not up on codes. Staggering seams in general is better. In real life, I doubt there would be too much strength loss and your build factor of safety is high anyways.
   / New garage time!
Overall overhang is about 1/8" all around now. Plywood is lapping from 1st to second floor. I'm not one to cut corners, but cutting those things on the ground on the horses was a pain, Cutting them up there Would be a nightmare. I'm fairly sure I'd screw up a whole lot more taking it all down again and cutting 3/4" off. I'm also pretty sure my buddy would quit on me if I told him that. I may come up with something else but for now I'm not so sure.
Weather didn't hold that well today. Still, got the walls pulled out and lined up, got everything even. All end plates screwed in and everything is tight. Checked square at the top and i'm 1" out, so I hooked up 2 ratchet straps to the long corners at the top and tightened down. Sure enough the sky opened up right then on us. I was completely drenched by the time I got off the scaffolding, and I was moving. Grabbed the drills and under the back porch roof. Almost forgot the windows in the truck. Left me completely drenched. Still, a good time.
   / New garage time! #634
Could put thin sheathing under a thicker sheathing, thin only to take up space except at the joists.
   / New garage time! #635
Yep, especially if trying to hide it and not create a transition. Personally I think a 'banded' look could add some architectural flair.
   / New garage time! #636
What ever you do, don't compromise your sheeting on the front end wall with the doors. Pretty big racking potential to resist there with 2 more floors to catch the wind. I believe they recommend nails every 3" on the sheeting in that application. On my garage I sheeted inside and outside around the doors.
   / New garage time!
Could you elaborate? I'm not sure i understood what you're saying.
   / New garage time! #638
Yes, I would not want 3 stories on a building that narrow.
   / New garage time!
Keep in mind the roof will be directly connected to the footer with 6x 3/4" all thread encased in 6 block deep in concrete.
Bridging almost done. Maximum spacing is 8' per the manufacturer. Reasonably simple to do so I'm doing a bit extra. There will be a 4th row installed as well, then plywood going up. I'll position the drywall hoist in the opening in the back and should be able to send 4 sheets up at a time.
Had a ton of rain, combined with dirt and sawdust, I'm hoping to get it dried out and hit it with the leaf blower this weekend, then start hauling plywood in.
Aluminum Alligator (A57454)
Aluminum Alligator...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
Unverferth Road Runner Head Cart (A59814)
Unverferth Road...
2025 Leopard F50 X-pro Mini Dirt Bike (A56859)
2025 Leopard F50...
404 (A52706)
404 (A52706)
2005 JOHN DEERE 160C LC EXCAVATOR (A59823)
2005 JOHN DEERE...
