New garage time!
/ New garage time! #21
Ok got a question. I need to remove the topsoil, 6" down BEFORE the footers are dug. I'm not sure the best way to do this.
The backhoe
I would dig it with the hoe bucket and pile the dirt where I could get it with the front bucket, and then haul it to where it needs to one bucket at a time.
Do you really have top soil? Is it loamy and organic? I consistently see people post pictures of what they call topsoil on their places, and to me, it is not top soil, and it was a wast of time to remove it. Where I live in East Texas, we do not have top soil. Where I used to live in CA, the organic loam went down a hundred feet and required significant footings, but once you got into the hills and, there was no top soil and the foundations where designed for earthquakes.
If you actually have 6 inches of topsoil, are you replacing it with gravel that you will have to compact or clean fill that you will have to compact?
If you do not have top soil, then you do not have to pay for fill material that is very difficult to compact.
/ New garage time! #22
I really want to follow this as well. My dream after #3 and #4 are out of college is to build a shop / mancave / living area here in upstate NY. Just curious I saw radiant heat but what fuel ? Oil, Nat Gas, LP or wood ? Radiant implies a hot water boiler and you can easily add a separate zone for a water heater off the boiler. Thanks for the pictures.
/ New garage time!
I consider topsoil the part where the grass/roots are. Under that it's hard, but if you put it on top of where grass is growing, the grass/roots will die, it will break down, and it can sink, thus creating foundation issues.
I don't know what I'm going to do for radiant heat yet. For now I'm concentrating on the building, and my entire budget is going towards the biggest building I can afford. I'm not even doing floors aside from plywood around the perimiter on second and 3rd floors to start, so it'll be all open aside from the floor joists. I'm 35 now so I hope to get 50 years out of this building and if it takes a while to finish, I'm 100% ok with that. For now I just want to get in out of the elements. I have 8 cars and 3 car garage right now, i need more space.
/ New garage time!
Once top soil is off, it'll be backfilled with 2b stone and i'll compact it with one of those compactors.
/ New garage time!
Cleaned up the garage site, got the plans finished up. Going to trench to a lower portion of the yard so water drains out of the dig site. It is raining a lot and the yard is a mess.
/ New garage time! #26
I don't see an $$$ elevator in the plans.
/ New garage time! #28
FJ: some of the builders around here use HAY to keep the mud at a minimum or because the inspectors make them buy it, but if you can get some cheap it might help your mud issues and maybe keep your machines from getting stuck.
good luck!!
/ New garage time!
The problem is 6" down is nothing but solid clay and it sucks for absorbsion. Straw prices are insane right now, $9 for square bales so I'd rather avoid it if I can. Since the yard is pitched once i have a trench it should drain pretty well.
/ New garage time! #30
FJ: just throwing it out there about the hay and sounds like you've researched it and hopefully your trenching will work.
good luck
/ New garage time! #31
I like all the detail that you have in your plan. Why are you using 2x8's for your framing?
/ New garage time!
Due to the 2nd and 3rd floor, it's structurally required for the 1st floor. The cost isn't much extra compared to 2x6's on the 2nd and 3rd floor, can shove more insulation, wiring, and plumbing in the wall.
/ New garage time! #33
Thanks. I've seen quite a few hotels built that are 3 stories tall and they all used 2x6's. I've never heard of anybody using 2x8's because of the extra money and dealing with how much heavier they are. But I've never built or lived in PA, so that's all new to me.
/ New garage time!
Got the excavation started. Block arrived. Permit arrived. Going to line it out on Saturday.
/ New garage time!
I’ll replace those upside down images when I get to a computer.
/ New garage time! #36
That's a lot of block!!! Your timing is perfect with everyone having to stay home right now. You'll be able to get a lot done.
/ New garage time!
A buddy of mine works for a lumber processing company that supplies other lumber companies that contractors use. Due to the virus and loss of business they're opening up to employee's buying materials. he said he can buy it for me at his cost, which is going to save me thousands. The only catch is i have to pick it up myself. Which means I get to buy a new trailer!
/ New garage time! #38
Win - Win!
/ New garage time!
Staked the dig site. Bobcat starter bit the big one so I'm waiting on a replacement. Then i'll dig the driveway and have a stone guy come in and pour stone.
2022 EZ-GO ELITE...
2021 Weber CF 2-IIHD Plate Compactor (A61572)
2021 Weber CF...
HEIN-WERNER 1TON TRANSMISSION JACK (A65643)
HEIN-WERNER 1TON...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
