New garage time!
/ New garage time! #281
Wow! I've paid for a pumper twice. 20 years ago to do my ICF basement. That was $500 and had to come from 140 miles away. Last time we now have local pumpers and it cost $200 to do
the garage. That's a no brainer. You prices are cheap on the concrete but outrageous on the pumper. In your case though I think it would be money well spent.
I wanted a pumper truck, but the price was just to unreasonable. Truck rental is $250, concrete is $100/yard, totaling $1250. Pumper is an additional $1357. If it was an additional $500, maybe I could justify it.
/ New garage time! #282
Your pex layout looks really good. I would encourage you to add more ties. My first pour was tied much like yours and the pex wanted to float up. I had mine pressurized with air. Using water instead might help with that.
/ New garage time! #283
I'm with you there. Maybe the recommendations have changed over the years. I have no complaints on the way mine works. Putting up top just is making it more difficult than it needs to be.
I think the OP posted this earlier. I understand that he's trying to follow the advice he's been given by this site. I've never heard that before.
I've saw the pex tied to the rebar with the rebar on chairs placing it in the middle of the slab. I understand the OP is using the mesh to determine his spacing which is necessary because his rebar is on 24" center.
My biggest concern is dealing with the pex during pour with it that close to the surface. If he was pouring using a pumper truck I wouldn't be quite as concerned. Without one the majority of this wet concrete will be moved with come alongs.
If I were his neighbor I'd show up to help. You can't get too much help on a project like this.
/ New garage time!
I just read all 27 pages. Well worth the read in my books!
I was just thinking to myself before I read the last post that a pumper truck in this situation would sure be nice. Then I read your last post. I concluded with the thought that for $1357 a pumper truck would still be nice. I can relate to your internal debate as I'm wired the same way.
What I like about the idea of a pumper truck is that the pump can put the concrete where you want it and leaves you with the time and energy to make sure your concrete is level and that your pex/rebar etc stays in place. It will also help ensure that your pex doesn't get damaged. Honestly if you figure the price of the pumper truck and what it gives you for me it would be a close call. The price of your help and how tired you are going to be at the end of the day is worth something too.
Some more for you to think about....
Added a note of interest. I've been to Haiti several times to help drill water wells. They used to carry the concrete everywhere in bucket brigades because labor was cheap. Lately they've been using cement pumps. Not the large trucks we have but just a cement pump on a small trailer. They lay pipe out to where the cement is needed and pump it to the pouring point. If you could find something like that it could be a cheaper option.
Pumper truck would be fantastic, but the price is $1357 per truck, 2 trucks means $2700 extra. And they're only 3 miles away.
/ New garage time!
Something doesn’t sound right with that pricing.
I thought i misunderstood the first time the guy explained it to me so i asked him to clarify, then asked my buddy to call and he got the same thing. We both agree'd that it would be outrageous and unreasonable, it would more than double the price.
/ New garage time! #289
And no other options for a pumper? Sure would make your life easier and whole lot less stressful.
/ New garage time! #291
Is he saying $1357 per truck, or per pour. On the basement poured walls, one pumper for three concrete delivery trucks. Basement floor same thing. Garage and work shop buildings were the same. Same pumper truck here for multiple concrete delivery trucks. But each pour was continuous by a crew of 6 to 8 guys. 3 floors poured (different days) with 3 experiened owners, the rest were hired employees, some were green. Basement floor 1700 sq ft, garage 1400 sq ft, workshop 2600 sq ft. Pumper trucks costed $800 per time. I think there were 6 pumper trucks. I lost track of how many concrete delivery trucks, mostly at at 10 yards each. Jon
/ New garage time! #292
It appears to me the problem and cause of the multiple charges is how he has the concrete trucks scheduled. 1st at 8a.m. 2nd at 11a.m. 3rd at 2p.m.
With a pumper truck that spacing isn't necessary. All three trucks can come spread apart about 15 minutes. Might need a slightly larger split between 2nd and last just so you can special order amount needed.
I'm nervous about having a six hour spread between trucks. That's simply not going to work. You will be finishing the pour and trying to trowel the beginning load at the same time.
I'm excited to see it done and am hoping it goes smoothly.
/ New garage time! #293
I would be tempted to do some phoning/asking around.
I would be more than tempted! To me it’s not worth the risk, all things considered. You’ve saved quite a few nickels with the DIY so far but this is the critical stage. Thinking a few years from now the extra money spent will be mostly forgotten and you know the pumper will go so much smoother. Just my two cents.
/ New garage time! #294
Yep. Consolidate the delivery times and pay one pumper. Will take 15 minutes or less to unload a truck.
/ New garage time! #296
That sounds really strange.
With what has been said about the schedule, it makes a whole lot more sense. The truck would mean to come and go several times or wash out between loads.
I agree that with a pumper you should be able to schedule the trucks one right after another and not have the big break between them.
Aaron Z
/ New garage time! #297
Aaron Z
Yep. Don't know why the trucks are scheduled so far apart. I could see if it was 3 distinct areas. But if it's one continuous pour, you wouldn't want to stop between them, would you?
We just poured the first of three 8' x 24' by 5" sections of a 24' x 24' pad yesterday for our garage storage addition. I'm doing it in 3 pours because we don't have the skill or strength to do more than that at a time. The truck can't get back to the area because of abandoned septic tank and soft soil, so I had to bucket the cement back there 1/3 yard at a time with my machine. Wife, daughter and future son in law raked, spread and screeded while I delivered. It took nearly 1 hour from start to finish and then didn't have much time to float before it was hardening up too much to do anything to. Definitely couldn't have waited 2 more hours for the next load.
So I can see how a pumper would have to be cleaned out if they were waiting a couple hours between loads, based on my experience yesterday. Concrete: it gets hard. :rolleyes:
/ New garage time! #298
Can you offer tips, hints on what the OP should do here? Thanks.
I already told him that putting the PEX near the top of the slab was not smart. I don't care who says what, it's a dumb move that has no basis in reality. There's no good reason to put in near the surface but plenty of bad ones.
As far as pouring goes, I have 20" steel pins that I drive into the base. They have small holes drilled into them that I can slide a nail into at different heights. I typically will set the pins so the nails are 1/2" above the final grade. I've gotten where I can have up to about 12' in between pins/chalk lines on walls, but suspect most people can't do more than eight feet.
I simply get it as close as I can while pouring and then "darby" or "puddle" the concrete to level it more. Puddling consists of a 2x4 that's about 8-9' long with handles that come up high enough so I don't have to bend over. Sometimes I bullfloat the surface. Finally, I power trowel almost all my flatwork.
/ New garage time! #299
I'm willing to up this to .04 cents!
/ New garage time! #300
...The pour crew will likely be 2 guys 60+ who have been doing it for 40 years and 4 guys who are younger. First truck at 8am, 2nd truck at 11am, cleanup truck at 2pm. What day still not sure, it came down in sheets today. Hoping for next Saturday.
While I agree that a pumper truck would make the job a little easier, I don't think it's going to make it that much easier for this size of a pour. There are only a few areas that the cement trucks wont be able to reach with their chutes, and even with a pumper truck, pulling concrete is still required. Even if the pumper was $500 for the day, if it was my project, I would not hire a pumper truck. There isn't any real reason for having it.
Scheduling the trucks so far apart is a huge mistake. They need to be there half an hour apart. If you are spending more time then that unloading the mud, you are dealing with hard concrete. This entire pour, with all of it spread and screed and floated needs to be done in a couple of hours. That's all the time you have. Then you can power trowel if for another couple of hours.
If your guys really have 40 years experience, they will tell you to have the trucks there a 8 am, 830 am and 9 am. 6 guys is enough, but more would be better. Just be sure that everyone knows what their job is beforehand. Who is pulling mud. What tool are you using to do this? I forget the name of it, but Home Depot sells a tool for doing this that looks like an over sized how that's wider then a rake. You need at least 2 of these, and 4 would be better. The guys with the experience need to be working the screed, but one of them will probably be the boss and work the chute. So you will have a rookie on the screed. then you need a guy with a shovel to get mud to the low areas, or get it away from the front of the screed so they can work it properly. A seventh guy with a hoe will make it go foster and easier, and allow for dealing with surprises. There is no visiting, no talking, no debating once the trucks arrive. The clock is ticking and there is only one speed that everyone has to be moving.
You might need somebody to deal with the concrete trucks too. Getting them into position once the first one is done can take away from working the mud. Where will they wash out the trucks? Will there be any extra mud in the truck when the last one is done? where will you dump it? he wont take it back with him. How close is your order? Are you allowing for low spots and needing extra?
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2021 NEW HOLLAND 185 MANURE SPREADER (A64277)
2021 NEW HOLLAND...
2006 MACK VISION (A65643)
2006 MACK VISION...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
Dueling Tree (A65640)
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
