New garage time!
/ New garage time!
The chairs are behind all the toilet paper that's been hoarded....
You make me tired just watching. I hope you're a young man.
I stopped counting at 30 some time ago and haven't given it any more thought. And my wife/children aren't allowed to bring it up. But I do know after 4 hours with the jumping jack at the end of the day, I pulled the 200lb leveling rake back and forth 6 times. Some weird burst of energy.
/ New garage time! #183
Ahh, so you're 31 now. :)
/ New garage time! #184
If I remember correctly, your building is 24 feet wide. Is that from the inside of each wall? How big are garage door openings?
The reason I ask is that it looks really tight. Can you remove the middle blocks and go with a big metal post instead that will have the same strength, but give you another foot for each door?
Another consideration might be to remove the center post all together and bring the side walls in a little to give you one really big opening for garage door. In my experience, having room on the side walls is very important to me. With your garage doors so close to the side walls, if you drive a car into there, it's going to be tough squeezing in and out of the car with limited room for the doors to open.
It's a pain to change a plan while building, but it's even worse to realize that you could have done it differently when you are done and it's too late to make those changes.
/ New garage time!
It is 24' wide, 22'8" on the inside. There's a 10x10 garage door and a 10x8 garage door. I'm basing it off of my father's garage which is also 24' wide. I definitely want 2 distinct doors, not one big one in the front. My neighbor did that with his 22' wide garage, and i don't care for it personally. My truck just barely fits in an 8x8, thus going with a 10x10 to buy me some room, plus I'll be able to get my trailer in if I need to, which I really don't anticipate.
The goal is to do minimal actual work in the garage other than automotive work, the real workshop will be on the second floor, which will be wide open.
/ New garage time! #186
Does that mean both doors will be 10 feet WIDE?
/ New garage time! #187
My first shop that I built had a 12 foot wide door in it and that was a good size. My current shop, I thought I could get away with saving a buck on the door and have a 10 foot wide door. It's OK, but really smaller then I should have gone. I wont make that mistake again. I can drive my truck in it easy enough, but backing my trailer into takes more effort then I had to apply with the 12 foot door. The only time I put my trailer in my shop is when I have a pallet of concrete on it and we're about to get hit by a thunderstorm. I've done it twice now, and I remember hating it both times!!!!
/ New garage time!
One door 8’ wide one door 10’ wide both doors 10’ tall. It’s not about money, it’s about span. I don’t want a center post but I want 25lb dead load on the second floor, which means 24’ wide for the floor joists. At 11-3/4 tall. I went through everything possible for joists. Lvl’s, I joist, and decided on metal c joists at 12ga. They had the most load and they’re pre drilled. Lvl is 250$ each and 12” on center and couldn’t drill. I joist was a bit cheaper but didn’t have the load rating.
/ New garage time! #189
I was just thinking about Eddies comment about removing the middle blocks. Instead of 2' of middle blocks, what about 1' of middle blocks? Then you could have a 10' door and a 9' door. Eight feet is pretty narrow.
That said, you are doing awesome work.
/ New garage time! #190
Ya Jay, take these comments as educated suggestions but do what's best for you. You're doing great.
/ New garage time! #191
I've never met a man that built his own shop and didn't wish he'd done something different. Those that are completely satisfied with their shop didn't build it. :D
/ New garage time! #192
I am a land surveyor and have done a lot of building layout in my day. I’m curious into pic you show a level on a tripod with a concrete block tied to it. Why? Interesting thread and enjoy the pics.
/ New garage time! #193
Maybe to keep the tripod more steady?
/ New garage time! #195
/ New garage time! #197
The tripods we used had feet to step them in. On very rare occasions I would set something on the feet of the tripod if it was really windy. You had to be really careful though so you wouldn’t throw it out of level. I was more being curious then being critical.
In the last several years we staked the building without even setting up on the building corners. I did always try to check tape and measure the diagonals if possible. They still do construction very similar to what the OP is doing around here.
/ New garage time!
I did the surveying myself, i stepped the feet in every time i set it up. That was the first day, my contractor set it up. I'm not sure why he set it up like that.
/ New garage time! #199
I always find myself servicing a vehicle parked half way inside and even the 10x10 doors on my attached garage become a pain. My new shop, still under construction, will have one door 14x16. If that doesn't work, I give up.
/ New garage time!
This is why I wanted no posts. 24x44 of unobstructed space. I can park one car in the middle if I want. Sure there will be a workbench and tool chests in the back. But that still leaves lots of open space.
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
UNUSED WOLVERINE 7' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
