new ford 3000 owner
   / new ford 3000 owner
thanks. the part with the hole in the flange is item 11 in the gear drawing. not sure how to position the hole. item 16 is what is broken on the clutch. All six link arms are broken. Hoping I could just replace the link arms but I think you have to have a special fixture to remove the tension. appreciate all your help so far.
   / new ford 3000 owner #12
thanks. the part with the hole in the flange is item 11 in the gear drawing. not sure how to position the hole.[/QUOTE
That hole in the input shaft housing should be at the bottom. It is a weep hole. If the seal leaks any oil, it will drain out that hole into the bell housing instead of following the t/o bearing support tube to the clutch and soaking it.
thank you for confirming that. I also noticed no gasket behind that same part. I was thinking I should replace it.
looking also for items 16, 25 and 24 from the double clutch. not having much luck.
correction: item 24 on double clutch is what's broken. thinking i'll have to get it made. Otherwise have to spend the money on reman clutch. Problem being the ones i can find call for a 1.75" flywheel step spec. My current flywheel is 1.71 so I would have to spend more money on machine work then too
   / new ford 3000 owner #16
If you have a rebuilder in your area, you might check with them. They might have the parts or be able to order them.
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2020 JOHN DEERE 8370R LOT IDENTIFIER 247 (A53084)
2020 JOHN DEERE...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
