New BX25LB-R
/ New BX25LB-R #21
Congrats...Would like to see a pic or 2 of it...Also a pic of where the dealer welded the chain hooks on your FEL.
Don
/ New BX25LB-R
Will get some pictures on here Tuesday morning. I'll be sure and include the chain hooks. The timing couldn't be better - I'm having a pole barn built right now and need to dig a trench for the water and electric lines. Can't wait to get started!
/ New BX25LB-R #23
Thank you for all the info in this tread. 18K seems to be the price in this area also.
Has anyone heard the 2009 financing optioins?
Has anyone had experiance with a FEL mounted plow, vs the frame mounted front plow?
/ New BX25LB-R #25
Is your preference due to issues with the FEL plow?
/ New BX25LB-R #26
/ New BX25LB-R
Well the new little baby has arrived! Here she is with her "Big Momma"! Not mine - the contractors. You should be able to see the chain hooks that the dealer welded on the FEL. As posted elsewhere - all the little issues with the BX24 have been fixed. No jerking stops with the HST. Loader and BH both work at idle (slowly of course - but they do move). Seat swings around for BH use pretty easily and is comfortable. Fenders and hood are all metal now. So far everything seems to work perfectly and I'm very pleased with her. I'm taking it easy until I get her broke in but sure seems to have plenty of power to do what I need. Will post a thorough evaluation once I've had a chance to really put her to work. Happy New Year everybody!!!
/ New BX25LB-R #29
Congratulations and good luck with your new machine. I looked at the BX over and over again, I had a B6000E TLB for a while and man did I love my bota (bought a second B6000E just because, I also had the matching rear finish mower and tiller). If my ground was just a little less narly I would've gone with the BX, but I had to go bigger.
You'll be handing that machine down through the generations, Kubota makes real good, tough, stuff.
Joel
/ New BX25LB-R
That was the dealers decision. Not sure of the reasoning behind it.
/ New BX25LB-R #31
I find that somewhat odd with hooks on the side. IF you need to go into places and the hooks are in the way then what ? I would ask dealer if he can modify the hooks location for you since they didnt ask you where you wanted them.
/ New BX25LB-R #32
I agree with moving the hooks. I don't want to think how much brush mine would have caught if mounted like that. I also like being able to get the bucket in close to walls etc. Those hooks would be scratching siding badly in my hands...
/ New BX25LB-R #33
i agree they are in a bit of a weird place. but....
1. i can't think of really any situation where the would have stopped me from doing the things i have done with my bx24 JUST because of the location.
2. you really need a way to lift from the center of the bucket. i have had loads the bucket could lift but the back of the tractor couldn't hold down. it is scary when you have all the weight lifting on one side of the bucket and the opposite rear wheel starts to come off the ground!
3. if you didn't specify where YOU wanted them, and the dealer put them where he thought they should go, you don't have much room to argue. they might change them for free just to be nice, but my experience is the dealer is there to make a profit just like everyone else. the first stab at the job is free, after that and the sale is complete, they need to get their shop rate to keep the doors open.
that said, you could easily add a center hook or d-ring with a welder or a drill and some bolts. there is a perfect, reinforced area for a small d-ring right where the middle cylinder connects to the bucket. i found a small ring rated for 1,200 lbs that far exceeds anything our tractors could lift.
if they bother you on the sides, just grind 'em off.
amp
/ New BX25LB-R #34
My dealer welds three short pieces of angle iron on the top of the bucket. One on each end, and one in the middle, and then mounts the hooks to those. I like that approach very much, and I haven't seen one of the buckets done that way damaged. Here is a photo of one he did. It's dark, and cold out there right now, but if you want closer photos, I'll take some of mine for you.
/ New BX25LB-R #35
My dealer mounted my hooks similar to LearJets, except turned 90* up. I never specified where I wanted them and when it was delivered, the salesman said that where they put them was the best position for the BX loader. There really isn't a flat top edge on the BX loaders so it seemed to make sense to me. Never had any issues with clearance, but mine are tighter to the bucket than LJ's.
Here's a pic of the BX1850, prior to trading it back for an 1860. I kept the loader.
/ New BX25LB-R #36
I'm not sure that I'd want to be lifting the full FEL capacity from the outside of the bucket. Seems like a lot of twisting action on the FEL and tractor frame. You'll just have to make sure that the load is slung between both hooks. FWIW - I have just one hook and it's bolted to the top of the bucket, right in front of the curl cylinder.
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2017 Ford Explorer 4x4 (A62679)
2017 Ford Explorer...
2016 Freightliner 108SD Truck (A64194)
2016 Freightliner...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2022 EZ-GO ELITE...
