NEW BX25 comming.. What upgrades do I want?
/ NEW BX25 comming.. What upgrades do I want? #1
hevnbnd
Hello, I should be getting my new bx25 w/ r4 tires and a Land Pride Box blade next week. I got this for $16,400 plus $125 Fees FYI.
I am already looking for all the upgrades I need for it. I have come across several different sites while searching the forums for hours. Bro-Tech was one and I was looking at getting the following from them.
Front Skid
Rear Skid
Thumb
Ripper Tooth w/ Trencher
Steering Guard w/ Tool Box
Rear Wheel Spacers
I also have seen a thumb from Wallenstein and wondered if I should get it or the Bro-Tech one.
I am looking at getting either a Land Pride PHD or a Woods.
What other upgrades or implements should I look into getting? Any input would be great. Thanks for your time!
/ NEW BX25 comming.. What upgrades do I want? #2
Definitely skid plates, buy or make your own but as someone posted before, as soon as you don't put one on, off come the fan blades!!
I love my thumb, don't know about wheel spacers. I guess that depends on your property.
Deano
/ NEW BX25 comming.. What upgrades do I want? #3
Front Skid
Rear Skid
Thumb
Rear Wheel Spacers
You will need to purchase the optional 3 point hitch in order to operate this with the BX25.
/ NEW BX25 comming.. What upgrades do I want? #4
Q: What upgrades do I want?
A: ALL of them :)
/ NEW BX25 comming.. What upgrades do I want? #5
One of the first things I did was add lights to mine.
/ NEW BX25 comming.. What upgrades do I want? #7
Best thing I added was a stearing wheel spinner knob
/ NEW BX25 comming.. What upgrades do I want? #8
Suicide knob and fill the rear tires. Having the backhoe on the back makes great ballast, but loaded tires lower your center of gravity a lot, and will let you use the loader without the backhoe on.
You can never have too much weight on these little tractors
Keep it coming. Anything I need to do to the tractor to improve it that does not cost a lot?
/ NEW BX25 comming.. What upgrades do I want? #10
loaded tires alone is not enough to operate the loader with .
The BH is around 600 pounds removing it and replacing with filled tires leaves you several hundred pounds short on needed ballast.
/ NEW BX25 comming.. What upgrades do I want? #11
One thing you need to add is Lots of FEL/BH/BB time...Congrats on your new tractor!
Don
/ NEW BX25 comming.. What upgrades do I want? #12
The cheapest upgrade you can make is to replace the key-chain type rings that the 3 point kit comes with to secure the kit to the tractor's lift arms with easier to use clips. The rings are a pain in the neck to take on and off. I'm assuming the setup is the same as on my BX-24. I replaced them with these:
/ NEW BX25 comming.. What upgrades do I want? #13
Congratulations on the new machine. You might want to have them weld a couple of hooks on the FEL. I have one grab hook in the middle, and find it very useful. BTW, I think the ripper is great, especially for roots and picking rocks from the lawn.
Ken
Man that is a big rock... I am should be getting the tractor Monday. I am also trying to talk them down on a Land Pride PHD. I have got them down to $850 so far, but would like to spend around $650 for it.... Guess I will find out how cheap I can get it on Monday.
/ NEW BX25 comming.. What upgrades do I want? #15
Toothbar for FEL is only $200 or so, Markham is most popular manufacturer.
Bucket hooks for FEL and BH are inexpensive, a thread in archives has numerous ideas. There are weld on, bolt on; I drilled holes in FEL bucket sides and put HD spring clips in when needed. Hooks also vary depending on whether it is a chain hook or slip hook (for nylon straps). Obviously chain and/or straps to go with this.
If you have the MMM, Larry @ MowerAxle has storage wheels that let you turn the deck vertically and roll it into storage. They are inexpensive.
A big funnel with filter can be helpful when fueling. I have a 17" dia. funnel that I got from a racing supply store. You also need to decide whether you're going to get 3 or so 5 gal. yellow diesel canisters by Blitz, or perhaps a "fueling station" of which N. H. Northern Tool and Supply carries several. I am currently designing/building a little boom arm which will quickly/easily clip to ROPS and support 5 gal. fuel canister while I tip and pour fuel.
Virtually all my implements are on dollies that I custom made for each one. Makes changing implements infinitely easier.
If you live where it freezes, you need to keep some extra Super UDT on hand. If it never freezes where you live, then you should keep some regular UDT on hand (both are made by Kubota and are superior hydro oil-they are the same except that the "super" has an additive to prevent gelling in cold weather-and costs more). I took a 5" funnel and stuck the small end into 2' of clear plastic tubing-this makes adding hydro fluid in that rear port so much easier. Also some extra coolant, engine oil, etc.
A "carry all" costs only $100-$200 and allows you to haul all kinds of stuff at the 3ph. I also bought a 15 gal. electric sprayer for an ATV, which I bungee strap to the carry all when I need to spray Roundup. The sprayer was only $90 vs. one with its own frame and wheels for several hundred. This more than paid for the carry all.
It was 111 degrees F this week at my house. I brush hogged while wearing a vest into which go plastic packets of chemical which freezes at 65 degrees. They stay at 65 degrees for about 3 hours while body heat melts the chemicals from solid to liquid. They really suck the excess heat out of the torso and keep the chest area at a comfortable temperature (water ice would be too cold). I keep an extra set of packets in the freezer and swap them every 2 hours. It made driving the tractor in 111 degree heat totally bearable. Gatoraide helps too. :)
Ear protection, eye protection, dust mask, etc. as needed, depending on how you are using the tractor.
Electric air pump (or bike pump if on a budget). You aren't going to drive the tractor to the gas station when the tire needs a little air.
It helps to have an extra pin and clip or two. Check and see if there's a TSC store (Tractor Supply Company) near you. If so, go browse around. Tisco makes a top link that's shorter than the Kubota one. Occasionally that's needed on some 3ph implements.
About 2 years ago, the "Attachments" forum had a thread entitled something like "What attachment do you use least of all and wish you'd never bought?" I'd say 95% of the responses were PHD. The tractor type will not dig in true hardpan (skid steer with correct auger will). Downpressure units and augers with Pengo carbide tips and bits can help in hard soil. If you are digging holes for planting things, your backhoe is better suited anyway. If you are putting up fence posts for a living and have no bedrock or hardpan, then it might be worth buying. Mine just sits. I would suggest that you try using just the bh for a year or two and see if that meets your needs. If you still feel you really need it, you can always get it later. OTOH, if you buy it and don't use it, it can be difficult to recoup the investment (and it takes up space).
Good luck and have fun with that new toy, er...sorry....tool.
/ NEW BX25 comming.. What upgrades do I want? #17
This ============ or this is nice for fueling up the tractor .
Wonder if you need a hazmat containment system??? The way our laws are, you might be illegal with all that fuel stored like that Lee...:eek:
I read the same post about the PHDs Here is my situation. I am building a new house hence the purchase of the tractor. I am putting up a deck on the back and fencing in about 1 acre. So I am going to either need to rent one several days or buy one. I don't mind buying one if it will work... I have a lot of rocks as I am building on a hill. I have tried the one man auger's and found the pretty useless in our area. So what to do....
/ NEW BX25 comming.. What upgrades do I want? #19
Rent one for tractor.
RENT ONE>>> That defeats the purpose of buying one. If I spend $100 renting one and it works I could have applied that to a post hole digger and if it does not I have wasted a post hole digger... I bought one for $850 from the dealer I bought my tractor from. I also just ordered from brotek a front & rear skid, thumb, ripper, steering guard, tool box, & wheel spacers... What is next...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2022 FORD E350 BOX TRUCK (A59905)
2022 FORD E350 BOX...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
HOMEADE 64" X 14' DOUBLE AXLE TRAILER (A60430)
HOMEADE 64" X 14'...
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
