NEW BX25 comming.. What upgrades do I want?
/ NEW BX25 comming.. What upgrades do I want? #1
hevnbnd
Member
Hello, I should be getting my new bx25 w/ r4 tires and a Land Pride Box blade next week. I got this for $16,400 plus $125 Fees FYI.
I am already looking for all the upgrades I need for it. I have come across several different sites while searching the forums for hours. Bro-Tech was one and I was looking at getting the following from them.
Front Skid
Rear Skid
Thumb
Ripper Tooth w/ Trencher
Steering Guard w/ Tool Box
Rear Wheel Spacers
I also have seen a thumb from Wallenstein and wondered if I should get it or the Bro-Tech one.
I am looking at getting either a Land Pride PHD or a Woods.
What other upgrades or implements should I look into getting? Any input would be great. Thanks for your time!
/ NEW BX25 comming.. What upgrades do I want? #2
Definitely skid plates, buy or make your own but as someone posted before, as soon as you don't put one on, off come the fan blades!!
I love my thumb, don't know about wheel spacers. I guess that depends on your property.
Deano
/ NEW BX25 comming.. What upgrades do I want? #3
Front Skid
Rear Skid
Thumb
Rear Wheel Spacers
You will need to purchase the optional 3 point hitch in order to operate this with the BX25.
/ NEW BX25 comming.. What upgrades do I want? #4
Q: What upgrades do I want?
A: ALL of them :)
/ NEW BX25 comming.. What upgrades do I want? #5
One of the first things I did was add lights to mine.
/ NEW BX25 comming.. What upgrades do I want? #7
Best thing I added was a stearing wheel spinner knob
/ NEW BX25 comming.. What upgrades do I want? #8
Suicide knob and fill the rear tires. Having the backhoe on the back makes great ballast, but loaded tires lower your center of gravity a lot, and will let you use the loader without the backhoe on.
You can never have too much weight on these little tractors
Keep it coming. Anything I need to do to the tractor to improve it that does not cost a lot?
/ NEW BX25 comming.. What upgrades do I want? #10
loaded tires alone is not enough to operate the loader with .
The BH is around 600 pounds removing it and replacing with filled tires leaves you several hundred pounds short on needed ballast.
2005 Isuzu NQR 4 door box truck with folding gate (A61307)
2005 Isuzu NQR 4...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
bad boy zero turn 72 (A56859)
bad boy zero turn...
INOP/NON-RUNNING 1997 GMC T7500 Truck, VIN # 1GDJ7C1P2VJ505340 (A61165)
INOP/NON-RUNNING...
2016 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2016 CHEVROLET...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
