New 5055e
/ New 5055e #1
mingoman
650 John Deere
My old 650 can finally get a much needed rest. I've been looking for a replacement for some time and finally decided on another Deere.
Getting it delivered next week along with the land pride cutter after they install the fel and radio. 20200910_124943.jpg20200911_122455.jpg
/ New 5055e #2
Congrats!
That's a big jump in tractor size. I am hoping to jump to a mid size cab tractor some day. My backhoe has a cab with AC and it is much more pleasant to work in than my open station tractor.
/ New 5055e #4
Mighty fine looking unit. A suggestion. I can see by the pic you posted - the rear tires look to be over inflated. Be sure you check EVERYTHING on that new tractor when delivered and PRIOR to putting it to work.
ALL fluid levels - ALL bolts tight and torqued down. THEN read your new OP manual - cover to cover with understanding.
You might call the dealer and see if you can get your OP manual now. Good chance to read it and gain understanding prior to delivery.
/ New 5055e #5
Great advice above.
Definitely put a pull handle on the lugs and check the tire pressure. Over inflated tires are easily punchered and don't come with road hazard.
John Deere has operator manuals online for most current models.
OMSJ16026
/ New 5055e #6
After checking bolt torque, take a black sharpie and put a line from the head of the bolt to the plate. A quick glance at the bolts after that will tell you they are still tight.
/ New 5055e #7
Tires also look to be mounted at the narrowest width. Good for transporting and flat country. This what you want?
/ New 5055e
Thanks for the feedback all and will do. I will be mowing in rolling hills so I'll check on that this week before they deliver it.
/ New 5055e #9
What a beautiful tractor. Congrats. If you know what tire width you want, it might be worth having the dealer adjust the tread before he delivers it. Those wheels are HEAVY, and the wheel lug torque takes the next size larger tools.
Love the way it looks.
rScotty
/ New 5055e #10
Good point rScotty. Mine are adjusted out to the next to widest setting. Mine are loaded with RimGuard - estimated weight per tire ~ 1000# or more. The dealer didn't mind making this adjustment and his tilt-bed truck was more than wide enough to transport at this wider setting.
/ New 5055e #11
Yep, I still remember the first time I had to deal with a flat tire on the big JD. And that was just a FRONT tire...It's sure not like changing the spare on our PU.
Here our soil is a dry sandy & granite-base gravel typical of the Rocky Mountains. There isn't much clay or mud for lugs to grab. So instead of filling the tires we tend to run them wide. In some of the valleys there is more clay soil and they fill their tires.
/ New 5055e #12
I got tractor envy.:ashamed: I didn't know Deere dealers sold LP . Where is the green paint? :confused3::drink:
/ New 5055e #13
My LandPride chipper came with green paint.. from a Kubota dealer no less.. when they learned I would be running it with my 4300, they offered to make it a green one.
/ New 5055e
Had no idea this could be done!
It was in stock at the local Kubota dealer, however.
I wanted something 8' wide and capable of cutting at least 3" brush. I believe Deere makes a 10' but it takes more tractor.
As it is the 5055e just has enough.
/ New 5055e
rScotty
Thanks! I called this morning and they're going to widen the stance up for me.
/ New 5055e #17
Good looking tractor. Just bought mine as well. 5090. I had a 5310, basically the same size as yours, since 2002. Best thing I ever bought. Never had any issues with it. I just hope the new one is as reliable.
/ New 5055e
Thanks! Good luck with your new one too.
/ New 5055e
Case skid steer wheels and tires (A63689)
Case skid steer...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2026 Electric Tricycle (A64194)
2026 Electric...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2015 FREIGHTLINER...
