New 4110 Impressions
/ New 4110 Impressions #1
Tombo
Casco, Maine
none yet
Well, I have had my machine for close to a month now. I think it is really great except for two idiosyncracies:
1). When you turn the wheels all the way to the left, they rub on the backhoe mounting bracket. I can fix this easilly enough with a grinder, but still...
2). When you turn the wheels all the way to the right, they catch on the hydraulic hoses to the loader. I can fix this with a tie-wrap, but still...
All things considered, I would buy another. It starts great, the hydraulics are quick and it is really fun.
I just wonder if anyone else had experienced any similar issues?
/ New 4110 Impressions #2
Glad to hear you're having fun with your new tractor Tombo. JD must need a better hose routing engineer as I have a similar problem on my 790 with the FEL hoses. The wireform bracket is just not up to the task. I have put extra wrapping and some big wireties around to protect but I still get rubbing sometimes /forums/images/graemlins/smile.gif
/ New 4110 Impressions #3
I don't have a backhoe on my 4010; so I don't have the left hand problem. Don't have the right hand one either. My hoses are nicely gathered and protected by like a black mesh netting. I'd think the 4010 and 4110 are almost identical except for 2 more hp in the engine and sep. power steering pump and about 20% higher rate hydraulics. Think I maybe should shoot a pic of my right side stuff.
Will go out there and do so.
Ralph
/ New 4110 Impressions #4
Tombo,
I don't have my backhoe yet, so I can't comment on that problem, but I don't have the problem with the front tire rubbing against the hydraulic lines either. I took a photo of the fabric around the hydraulic lines on my 4110. All the rubber lines are nicely tucked in the loader's support arm.
Hypernix
/ New 4110 Impressions #5
My older 4100 had issues with the hose-holding bracket until the hoses caught on the front tire real good one day and bent the heck out of the bracket.
I removed the bracket and now use a bungee to keep the hoses up and out of the way with both the loader and my front blade or snowblower.
I was taught by an experienced automotive engineer that
"Anything held on by one fastener will eventually fall off. Two and it might last a bit longer. Three or more is good."
Something about the vibration and that one screw will always loosen and that is exactly what happened to the hose bracket on my 4100.
- Rick
/ New 4110 Impressions #6
Hypermix beat me to it. That's exactly what my 4010 with 410 loader looks like. Someone must have bent a bundle of lines on your 4110.
Ralph
/ New 4110 Impressions #7
Tombo,
I have the 4110 with BH & FEL, I don't have either issue, it sounds like your install might not be correct. This photo is from just above the front left tire looking into the BH subframe mounting bracket - it attaches to the FEL support. Nothing extends in front of the FEL mounting frame. There's easily a couple of inches between the tire and mount when fully turned to the left. 2 more pics to follow.
-Norm
/ New 4110 Impressions #8
This is from behind the left front tire looking into the BH subframe mount.
-N
/ New 4110 Impressions #9
And this is of the right front tire looking at the hydraulic lines. Not even close to the tire. As Hypernix said, they're snaked thru a sleeve (looks like snake skin) and then tucked thru the loader arms. Sorry the pics are a little fuzzy, first time trying to compress them to fit within the TBN file size requirements.
-Norm
GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
GENERAC MOBILE...
20' CONNEX BOX (A67714)
20' CONNEX BOX...
PORTA POTTY (A68842)
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
PALLET OF HOSE REELS (A67714)
PALLET OF HOSE...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
