New 3520 -- need advice
/ New 3520 -- need advice #1
Phunge
Hello,
Upgrading from a 2320 to a 3520 with the following attachments:
  • 485 Backhoe + thumb
  • 300cx loader + 4in1 bucket
  • 72d deck
  • 59" front snowblower
  • B2060 box blade
Got tired of waiting for the 270 backhoe, and have a bunch of projects (stone work) for which I need the increased capacity of the 300cx and 485 anyways.
I'm all set to do the deal, but am undecided on which tires. My 2320 has the R4s, and while i'm careful not to tread on my yard when wet, I am noticing certain areas are getting quite compacted. I'm thinking I will go with the turfs this time, which will hopefully offset the additional weight of the 3520. Mostly the 3520 will be used to landscape my property, so will be operating on my lawn for the most part. I have two concerns about the turf tires, though:
  • I have some fairly steep hills that I mow. Will the R3s have enough traction to get up and down without sliding? Maybe I just need to stay off the hills when wet?
  • My driveway also has a fairly steep hill. In the winter it ices up quite a bit -- I use a 3pt spreader to put sand/salt down and have had no traction problems with the 2320 & R4s. Will the 3520 with R3s be OK in the snow? I figure the 'Turf' tread is still more aggresive than my pickup truck tires, and it's like a tank in 4x4. Not interested in using chains, I hate wrestling with them to get them on, and don't want to wreck my garage floor.
I've waffled back and forth between the small R4s, big R4s and Turfs several times. I've even contemplated ordering a set of R1s to use in the winter or when I need extra traction. I figure with the BH and Loader and impact gun it would be pretty easy to change the tires. It's a fair amount of extra expense, though, plus i have to store them.
Would apreciate any advice.
/ New 3520 -- need advice #2
turf tires you wont need chains in snow. it is the same as having a good winter tire on a plow truck.
Thanks, that's what I was thinking as well.
/ New 3520 -- need advice #4
Hello,
  • 72d deck
  • B2060 box blade
I'm thinking about doing the exact same thing, trading in my 2320 for a 3520. My 2320 is in the shop (Been over a month.) so the dealer gave me a 3520 as a loner with R4's, and finish mower. I don't really notice too much difference on the yard from when I'm mowing with my 2320. However, I was also thinking about getting R3's, but are they tough enough to handle loader work and rocks? If you do the deal, I would like to know what you think.
Decided to go with the large r4s. I've been happy with the r4s on my 2320, so I decided to play it safe. They may be harder on the lawn, but safer on my hills.
the cost to swap the tires later is huge. Still second guessing though.
Now i wait, will take a month to get the tractor from the factory.
/ New 3520 -- need advice #6
Why do you think the R4's are safer on the hills (I have hills too.)? I thought the R3's were the same sizes as the bigger R4's.
/ New 3520 -- need advice #7
Traction makes them safer. Less slipping and sliding when going up, down, or sideways if it is damp/wet at all.
That was my thinking. I've not tried R3s, so I could be wrong, but I know my R4s have been great in this regard on my 2320.
/ New 3520 -- need advice #9
The loaner 3520 with R4's, and a cab like to spin when I'm mowing on a slope. I thinking the man reason for this is the loader is on, and I dont think the rear tires are loaded. With that cab, and not having the tires loaded it gets a little scary. If it were mine I would be ordering wheel spacers!
/ New 3520 -- need advice #10
That's a blanket statement and not correct in all circumstances.
I do see the OP decided to go with R-4s...probably a good decision.
My 2320 w/R4s will do this if I have the loader on without the ballast box. The rears will spin because the weight is biased to the front. Without the loader, or with the loader & ballast box, it's fine. My tires are not loaded.
/ New 3520 -- need advice #12
Most everything I say is just from my own experience and I shouldve stated as such not to step on any toes. When I plow under contract with my employer, anything with ag tires gets no where on any type of grade. Flat terrain in the snow is ok. Once your in a snow storm though, the ag tires are goin absolutely no where up hill fast with anything in the bucket/ or blade. 2 years ago, i made a pass down hill in a narrow path and then was half way going back up hill with the bucket in the air with a cat 416 and the machine lost it. Just started spinning and started going backwards REAL fast almost lost the machine and rolled it but gods hand stopped me somehow. For me, turf tires never let me down in snow. Lets face it though, ag tires have FAR less bite in the snow versus turf tires. Shouldnt be any dispute over this. Turf tires have lots of tread to bite into snow. AG's bars just ride on snow. Like i said though. Whats the point of getting turf tires unless you plan on mowing a lot of just moving snow. If your going to use your tractor as it should and play in the dirt more than you mow, go with the r4s. When i get a loader, Im gonna have to buy chains becuase this machine gets absolutely no traction whatsoever in the dirt obviously haha. Notice right away when i used my subsoiler in damp terrain. I even got the thing stuck already d.a.m.mit*
/ New 3520 -- need advice #13
I was thinking of going with the R3's, but after playing around with the 3520 I think I've changed my mind.
They need to make transformer tires.. R1's and then you flip a switch, and there R3's. :thumbsup:
/ New 3520 -- need advice #14
Front turfs will not hold the weight of a full bucket as well as R4 tires will. The turfs are only 4 ply, and the R4 tires are 6 ply. I own the 3720, and when I can afford tires, it will get R1 radials in the back, the giant ones. And I would keep the R4 in front, for loader work. I do not mow with this tractor.
/ New 3520 -- need advice #15
Hello,
  • 72d deck
  • B2060 box blade
May I ask what kind of deal you got on that package?
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2016 Dodge Grand Caravan SE Plus (A59231)
2016 Dodge Grand...
UNUSED IRANCH 22" MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 22"...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLFCART (A60430)
UNUSED SDLANCH...
