New 2810 question
/ New 2810 question #11
Old? Who's old? I reckon you just might be correct--but I'll never admit it! /forums/images/graemlins/grin.gif
/ New 2810 question #12
You tractor has a new restrictor that Branson recently started using because prior to that their loaders were way to fast for most users to handle. It's the one on the valve, just pull it off and drill it out a fraction reinstall and see if it helps,,, keep going until it runs at a speed you like. /forums/images/graemlins/grin.gif
/ New 2810 question #13
Jonathan,
There are about 3 different joystick valves used in the last year or so.
One was a non-float valve, the other two were float types. The non-float valve functioned well regarding speed, but was missing the float function and some wouldn't work two-functions at once. When placed in the diagonal, the loader would drop.
The float valves were very touchy regarding boom drop, especially with a load. You have to be real careful if you want to lower the boom just a little bit. This was fixed in coordination with Ansung and Bondioli by installing an orifice at the valve in one of the lines. The first orifices had a single larger hole and they worked well. For some reason, they switched over to a double hole orifice with smaller holes. On paper that works better, but in the real world it is too slow. Drilling both holes out to 0.0625 - 0.068 has worked great for us. Buy an extra bit, they break easy when they are this tiny! The dealer will do it for you at no charge.
The three-point valve is for regulating the descent of the three-point, I don't think it would have a direct correlation to the loader speed, but I've not tested it with that in mind.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
1667 (A57192)
1667 (A57192)
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
(INOP) 2011 FORD F-150 XL SINGLE CAB TRUCK (A59823)
(INOP) 2011 FORD...
