New 260 bogging
/ New 260 bogging #1
Brushhill dave
central alberta
kubota 2360,Ford 4610,111jd,gt200 husky
My new 260(4 cord cut) is bogging down when in wood and slow to rev up. Air filer is clean, fuel is fresh. My question: do new saws come detuned??
/ New 260 bogging #2
New saws come set lean due to EPA regs and usually the dealer will set them up fairly well within the limits of the tabs. I would start by replacing the plug if this is a new condition after several tankfuls.
/ New 260 bogging #3
How sharp is your chain?
/ New 260 bogging
Chain is sharp, i don't let them get too dull
/ New 260 bogging #5
Those 260s are legendary saws and dependable as gravity so I don't think you have anything more than a carb adjustment issue. If it is a new saw and under warranty I would take it to the dealer. Usually when a saw bogs down and won't accelerate either unloaded or not it is the L (low) speed carb screw needs richened up a tad. Turn the screw counter clockwise 1/4 of a turn and see what happens. Good luck with your saw
Steve:thumbsup:
/ New 260 bogging
No, I had started night shift the day you suggested I should, it's gonna be a long run but will let you know when I get a chance to adjust
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
2012 POLAR TANK TRAILER (A63569)
2012 POLAR TANK...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
2008 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2008 CM TRAILER...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
