New 2501 Questions
   / New 2501 Questions #1
Turbofire Orange
South
none
New member here...
Looks like 50 hr service I change oil and filter
and change hydrostatic filter (only).
Is this pretty much it ?
What grade oil for warm (32+) clime,
seems grade is dependent as to weather I have an EGR valve
which begs the next ? Do I have an EGR valve ?
Is there a grease fitting on FEL control valve ?
Lastly, Is there a way to reduce friction on hand throttle (very stiff) ?
Currently @ 10 hrs. One great lil' tractor !
   / New 2501 Questions #2
Change engine oil and filter,hydrostatic filter,grease everything,check front diff. and retorque wheels and FEL bolts.
Things are new and they will loosen up some with use.
   / New 2501 Questions #3
Hi welcome.
Most 50hr service intervals are filters and screens. You hydraulic suction line usually has a screen to trap large particles leftover from manufacturing.
You may want to use the shop vac method for changing the hyd. filter to keep from draining all the oil.
The engine oil can be any type that meets your manufacturers specs. The manual should identify what type is acceptable to maintain your warranty.
I am not familiar with your specific tractor as to whether or not it has an EGR valve. Your dealer could answer that.
The FEL control valve does not usually have a grease zerk.
The throttle control arm can be adjusted for tension. It needs to be tight enough to not move while operating. You don't want it speeding up or slowing down while operating.
   / New 2501 Questions #4
No grease fittings on the loader valve (assuming it's the LA525 loader). The fittings are all on the pins of the loader, usually at the ends of the cylinders. And if you have a skid-steer attachment on the loader, there are fittings on it too.
Don't forget the air filter. And check the coolant bottle. Clean the radiator (not just the screen). Check the fan belt tension while you're in there.
No EGR on the 2501 (yay!). It's just an L3200 with a different governor/injection pump. And of course a little different gearing in the transmission to compensate for the slower engine RPM.
Hand throttle has a pair of jam nuts on the bottom side of it to adjust the tension. However, I usually lubricate it before playing with the actual adjuster and 99.99% of the time it solves the problem of being stiff. Chain lube works great and stays on.
15w40 engine oil works well for most climates. The Yankees (northerners) might want to double check your manuals for oil recommendations as it'll change with the extreme cold that y'all get.
   / New 2501 Questions #5
Not sure about the 2501, but my near-identical 3200 called for both the HST and hydraulic filter to be changed at 50 hours, so two filters (in addition to engine oil and engine oil filter).
Gotcha on the hydraulic filter. A little confusing as it appears to be a common fill
for both hydraulic and hydrostatic fluid
(top of rear axle).
2501 engine is 100.47 CID, can't find this engine in any other models.
Produces HP down low at 2200 RPM
Thanks for throttle tip, it's nice and smooth now.
Can't get idle below 1000 RPM. Is this typical ?
   / New 2501 Questions #7
I have a L3901. big brother to your 2501. my owners manual was very clear on what all needed to be done at the 50hr service. it was oil and filter. and one hydraulic filter (the one under the left side when sitting on the tractor). all was very easy to do. there are grease fittings all over the loader. i try to hit them about every 10 hrs or so. im not sure about the EGR valve. i know mine has a DPF so i would assume it has one but not really sure...something ill have to check on now that you have me curious. i picked up all my oil and filters from the dealer so i knew i had what manufacture recommended.
K 3901,
No hydrastatic filter to change ?
2501 has both hydra and HST filters.
HST under left foot,
hyd under right foot @ FEL hoses, I believe.
   / New 2501 Questions #9
my manual and the dealer both said to just change the one on the left. they said the other one gets changed at the 400 hour service. i dont see where it would hurt to change it at the 50 hr service but according to them and kubota its not needed
   / New 2501 Questions #10
Same here. Still have a little more than 20 hours to go before it's time to do it.
City of Pinellas Park (16920) VIN: 1GNLCDECXGR265858, Title Brand: Police Year: 2016 Make: Chevro... (A51694)
City of Pinellas...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
