New 2305 is on the way!
   / New 2305 is on the way! #11
Where are you located??? The prices you received are exceptional and nothing in my area comes close. I know, regional pricing......
   / New 2305 is on the way! #12
This is the pricing I've received...the best so far.
John Deere 2305 Hydrostatic Compact Utility Tractor, R4 tires $10,000.00
John Deere 200CX front end loader, 53-inch bucket 2,435.00
John Deere 647 48-inch rotary tiller 1,716.00
John Deere 54C mower deck with independent lift 1,560.00
I've got a 2305 update for ya'll.
When I gave my down-payment to my dealer on Friday 8/12/05, he said that the 2305's were due to ship out of GA on 8/19/05. But, he also said that some of them already had tracking numbers in the computer, so they might arrive sooner. He e-mailed me Monday, 8/15/05, that my 2305 had arrived here in VA. I got a chance to stop by and see it briefly yesterday, and really crawled all over it and test drove it today, 8/18/05. Now he has three 2305's on his lot.
Here's my report.
It's about 90% the same as the 2210, with the following differences (working from top to bottom).
The higher back seat is the same as the X-series, but the suspension is exactly the same as the 2210 (as in; not really suspended at all). The early JD bulletin seemed to promise more, but it's not any different. My dealer has a suspension taken off of an X495, so I'm planning on using that.
Behind the seat, is a new bracket & hook for holding the top link of the 3 Pt. Hitch. It looks more substantial than the older set-up. The little bar that goes through the top link on the 2210 is gone (used for twisting?). Instead, there's a little welded loop. Maybe I'm supposed to stick a screwdriver though it for leverage?
The hood is sloped, but is still made of metal, like the 2210. I had hoped for a plastic hood, but, it'll have to do. The fuel-cap is black instead of red, and much smaller (2" opening vs. 4" hole). There's a black rubber grommet all around the metal edge of the circle cut out of the hood. The tank holds 0.5 gallons more. There's a little silver doo-dad on the front for decoration? I'm 6 feet tall, and from my normal sitting position, I was able to see about a foot more (closer) road over the 2305's sloped hood, than over a 2210's flat hood that was parked next to mine.
The hood now contains the wrap-around style headlights. They don't look like they'll be as bright as the 2210's Gator headlights. But, you'll never have to unplug them from the back, in order to remove the lower grill. So?
Under the hood, the new 24hp engine sports a slightly larger air-filter cannister. The same muffler is used, but it's now mounted on it's side, so that it's taller & thinner, rather than shorter & wider. The oil filler cap is located on top of the engine, between these two objects. This appears more convenient than the 2210's, which is down on the right side of the engine against the side panel of the grill. Access to the battery is better on the 2305, and the battery seems better mounted to the frame.
The lower grill and side panels of the 2305 are now all one piece, instead of the 3 pieces on the 2210. It seems easier to take off and put on. There's less screen area than on the 2210, but alot of the 2210's screened area is up against sheet metal, so the reduction in airflow is not much. Time will tell. This one piece panel is also scalloped up on both sides along the rear of the engine compartment. This reveals the 4 rubber engine mounts, which is not as nice looking as the 2210's skirting. But, it allows access to both the oil dipstick and oil filter without having to open the hood or take off a side panel. This appears very convenient, especially if an FEL is mounted. The fuel filter has been re-positioned up and behind the right-rear engine mount, providing some protection.
The dashboard is the same as the 2210. Right down to the small blank-out plate next to the steering column. This is where the Cruise Control switch will go (whenever it becomes available?) Makes me think that this same CC could be retrofitted onto older 2210's?
The hydro pedals are now made of hard black plastic with curved tube-steel connecting rods running down through the floor. These are the same pedals used on the 3X20 and 4X20 series. I like the 2210's (and 4000Ten's) rubber pedals better. The old multi-piece angled-steel connectors look stronger, and the new plastic doesn't grip the bottom of my boot as well as the old rubber pads. I could swap them out, but my dealer quoted me $250 for the older pedals, so, I'll try some non-skid paint first.
Underneath the tractor, is where I found 2 changes that I really don't like!
First, along the inside left of the frame on the 2210, there's a long gold-colored rod that runs from the brake pedal linkage to the rear trans-axle. It connects to a hydraulic cylinder/actuator? near the back. Although long & slender, it looked like an OK set-up, as it was tucked-up under the tractor and protected inside the left beam.
On the 2305, there are two shorter rods that are connected to the cylinder/actuator? via a bell-crank sort-a-thing. This connection is attached/braced against the left beam better at about the mid-point. But, it also forms a bend/elbow in the set-up, which causes the cylinder/actuator? to hang down below the left frame beam. This new set-up looks more vulnerable to whacks from below, or from the side. You can actually see this gold-colored cylinder/actuator? hanging down in the first promotional photo of the 2305 (that appeared in another thread), just in front of the left rear tire.
Second. On the 2210, the mower height adjustment knob is located close to the middle of the back of the flat operator's station. It has a flat round molding in the floor, just slightly larger than the knob itself, and a circular placard marked "Install,1,2,3,4,5,Lock". Underneath the tractor, the control box that the height knob connects to, is mounted to a heavy duty steel box that extends all the way across the frame from one side to the other. This set-up seems very strong, and maybe even increases the rigidity of the tractor's whole frame?
On the 2305, the cross-frame box has been replaced by a short steel shelf, that only bolts onto the right frame beam. It doesn't tie the frame's beams together, and because this shelf is further to the right of the tractor's centerline, the mower height adjustment knob has been relocated about 2" out into the right rear floor of the operator's station. Where it can be kicked/stepped on more often by my big right foot. The new molding in the floor is now an oblong stretching from the old circle's location in the middle to the new circle's location on the right. And the hole cut in the steel sub-floor, is not just under the knob, but was enlarged from the original hole. So, now theres a hole in the middle of the operator's station covered only by the thin rubber floor mat. You can press your finger through this soft spot easily while reaching to adjust the mower height knob. The new placard is marked "Install-Low-Medium-High-Lock" with the same number of adjustment clicks.
The only reason for either of these 2 changes, is that maybe JD is making room for the "independent MMM lift" option? Since this option isn't available yet, we'll have to wait & see?
Then, I took it for a spin. Just the basic tractor, no attachments; and it handled just like the 2210. The engine was slightly quieter at rated RPM (2900), and slightly smoother at idle, than the 2210, but not by much. I did an informal turning radius test in 2WD, and the 2305 tied an X585 for the tightest circle, but, only about 4 inches less than the 2210.
Some other notes:
My dealer is awaiting the new 2305 mounts for the 200CX loader. It seems that the 2210 mounts were made for the old 210 FEL. Then the 200CX came along, and JD supplied an "adapter kit" to fit the old 2210 mounts. Now, the 2305 will use new mounts made specifically for the 200CX.
In another thread, someone mentioned that the rest of the 2000-series tractors will be introduced at a show in Florida in November. My Dealer is scheduled to go to FL in NOV to attend "2000-series Tractor Training". Coincidence? I think not!
I'll type more after I take delivery. Dave.
PS - Anyone know of a "skid-plate" arrangement to protect the Hydraulic Filter underneath 2210/2305's ???
   / New 2305 is on the way! #14
BluRidgDav,
Thanks for the update; guess I'll be kicking some tires at my dealer this weekend! /forums/images/graemlins/grin.gif
   / New 2305 is on the way! #15
Dave,
Thanks for such an in-depth review! You certainly did your homework.
I think , that many of the points made here explain the pricing strategy. With the price of steel, fuel etc going up , and up, and up, they had to find ways to cut costs in manufacturing and design.
Your post shows that maybe on the outside, the tractors look and seem similar, but in reality, they did redesign quite a bit of the unit.
Thanks again!
/forums/images/graemlins/cool.gif
   / New 2305 is on the way! #16
Dutch,
Good point about the amount of redesign that had to go into the 2305, but I'm intrigued at how they cost-reduced it and yet ended up with a tractor that weighs 50 lbs. more. /forums/images/graemlins/tongue.gif
   / New 2305 is on the way! #17
Thanks for the very detailed and informative post. I enjoyed reading it.
Ken /forums/images/graemlins/smile.gif
   / New 2305 is on the way! #18
<font color="green"> Good point about the amount of redesign that had to go into the 2305, but I'm intrigued at how they cost-reduced it and yet ended up with a tractor that weighs 50 lbs. more </font>
Actually they cut about 1370 lbs...
   / New 2305 is on the way! #19
Did you start the motor? I'm curious about the sound of the redisigned motor, specifically the "quieter" cooling fan...
Fanatic,
For someone buying their first "real" tractor, (like me), the 2305 might be a better choice?
It has some convenient refinements and asthetically matches the new 200CX loader.
But, if I already owned a 2210, I wouldn't sell it to buy a 2305.
I'd move further up the tractor food chain to get something that offered a definite increase in capability from a sub-compact machine.
Dave.
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2005 Ford Freestyle Multipurpose Vehicle (MPV), VIN # 1FMZK01175GA19616 (A57453)
2005 Ford...
