Need utility Side by Side
/ Need utility Side by Side #181
We dont get the heat like you do. But we sure get the cold, snow,and rain
/ Need utility Side by Side #182
Guess glass vs hard coated polycarbonate windshields is like arguing who manufactures the best sxs lol. I'll be on the hard coated polycarbonate bandwagon until it lets me down for the price Ill pay for them. I can understand why some folks get glass windshields, but there not for me.
/ Need utility Side by Side #183
I went and kicked the tires at a dealer that handled Polaris, CF Moto, Kawasaki and Honda. I mainly just looked at Honda and Kawasaki. The salesman was sure pushing CF Moto and Polaris and those were most plentiful on their lot.
Polaris is the most common on all the job sites I go to, but folks that have owned Polaris, Kawasaki, Yamaha or Honda, always recommend the Kawasaki, Yamaha or Honda. I guess I'm a little up in the air of a 700cc or a 1000cc model. I don't care about speed or hauling loads, so I think a 700cc will suit me better.
A buddy of mine thinks the Yamaha will check all my boxes, and just from my on-line research I think I might agree, so I'll find a local dealer to look at those.
/ Need utility Side by Side #184
The poly one came as part of my UTV. A replacement is 1/2 the cost of glass. I can see glass advantages, but not for the cost given my uses.
/ Need utility Side by Side #185
When i shattered the glass windshield on my kioti tractor a few years back, i could not get a replacement right away due to covid parts supply issues. It being winter and snowing, i decided to try and make my own polycarbonate replacement to get me by. I went to 2 supply houses and the cost of the poly sheet was more than the cost of the glass replacement from kioti. Kiotis price was $505 incl shipping. They wanted nearly 700 for poly.
I ended up buying a cheap, ultra thin piece of plexyglass from home depot and made a temp window. It leaked, but kept snow out of cab.luckily within a month the windshield came in.
Their excuse, covid caused all their supplies to dwindle because everyone was installing them at registers, stores, banks, restaurants,etc. any excuse.
/ Need utility Side by Side #186
Probably won't matter to some but I wonder if some folks that buy a sxs consider the width and size of a trailer they might have to get to haul a sxs around? I've seen a few of the wider ones loaded single on car or even tandem equipment trailers going north for the weekend. I use my single axle utility type trailer with a 5.5' width I think it has close to a 14' long deck, has a fold down ramp in the back to haul my 5' wide wolverine or 50" wide pioneer, with a bit of room front and back to spare. Or I can haul two 4 wheelers at once in line. Definitely couldn't use that trailer nor would I want to use my tandem 20' deck over just to haul a wider 6'+ sxs lol.
/ Need utility Side by Side #187
Guaranteed those polycarbonate sheets were not hard coated. When COVID started dying down found 4 decent dimension uncut sheets of polycarbonate outside a restaurant for free still had the protective wrap on them, still debating what to make with them. Wonder if there's a diy hard coating polymer to spray on them?
/ Need utility Side by Side #188
Some buy the size that fits the truck bed…
When we bought the Kubota 900 home we used the dump trailer and your hand would not have fit between the Kubota and the trailer sides.
It sure did tow sweet behind the super duty on the 165 miles back to home.
/ Need utility Side by Side #189
If I'm in a pinch I've put my Honda pioneer 500 in the bed of my GMC pickup with 8' bed. truck has a tool box, have to leave the tailgate down. I prefer to trailer it though.
/ Need utility Side by Side #190
I could see injuring myself trying to get a SxS into a bed of a pickup. I don't even like driving my car on ramps to change the oil.
/ Need utility Side by Side #191
a few people I know are very hesitant driving atvs on ramps to load and unload in a pickup bed. Most ramps for that purpose have straps to hook on underside of bumper I definitely use the straps and take my time.
/ Need utility Side by Side #192
When I load something like a ATV in the bed of my truck I usually back up to a small hillside and use the ramps more like a bridge. Occasionally load snowmobiles in similar way backing up to a snow bank with tail gate down, using no ramps.
/ Need utility Side by Side #193
Getting them loaded that way is the easy part, getting my carcass back on the ground safely is another issue :)
/ Need utility Side by Side #194
All it takes is a major injury to realize it would have been cheaper to buy a small trailer.
/ Need utility Side by Side #196
My hunter friends trek to Montana and prefer bed loading because where they set up camp is already 4wd and taking a trailer in tow might be problematic depending on conditions…
A livestock chute works perfect for loading at the ranch and unloading at destination.
Also without trailer they can drive faster than 55 tow speed.
Maybe why there is a pickup bed size?
/ Need utility Side by Side #197
A livestock shoot works perfect for loading at the ranch and unloading at destination.
I'm seeing more contraptions called sled decks I believe to load 2 snow machines on a deck above the bed sides of a pickup truck. Instead of using a 2 place snowmobile trailer. if you used one for a sxs I could see you might need to get a permit or at least pre plan a route avoiding low bridges. I think you'd definitely be top heavy.
/ Need utility Side by Side #199
Is that still the law in CA? You can only drive 55mph when towing a trailer?
Ya, here in idaho most people ( usually contractors pulling enclosed box trailers) think they can exceed posted speed limits when pulling trailers. And most forget about the trailers when they decide to pull over into your lane.
/ Need utility Side by Side #200
Does Idaho have that law too? I grew up in CA and I remember when the speed limit was 55 for everything, and then they raised it to 65, but if you were towing a trailer, then it was still 55.
Every time I towed a trailer, I broke that law. I never got a ticket, but the cops would flash their headlights at me or pull up beside me and either honk their horn or turn on their interior light as they passed me. I always took that as a warning, so I slowed down. I don't remember anybody ever getting a speeding ticket for towing faster than 55, but I'm sure it happened.
Bobcat Turbo 873 Skid Steer (A62679)
Bobcat Turbo 873...
(5) John Deere Front Tractor Weights (A65640)
(5) John Deere...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A65563)
2006 GMC W3500...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
White 5100 12R Planter (A66285)
White 5100 12R...
1999 CHEVROLET 3500HD SERVICE TRUCK (A64277)
1999 CHEVROLET...
