Need to come up with a "crane" to lift trusses
   / Need to come up with a "crane" to lift trusses #41
That's OK assuming you have a rental place that has one when you need it and have something approaching level ground around where you're building. I have neither. This thread is for ways to home brew something using what we have on hand.
I'll be pouring a slab, so I'll have a nice solid level space to work on. Renting something is certainly not out of the question. I have a 4 ton car carrier trailer, so it would be easy to go pick up a machine. But if I have to spend $200 renting a machine, I would much rather spend that building a solid and safe attachment and have that available in the future, and then I have the flexibility to change schedule without worrying about lift availability. Some of these links showing extended booms on loaders are way beyond what I need. I'll only need a 9 foot boom.
   / Need to come up with a "crane" to lift trusses #43
I put a sheet of 3/4" plywood on my forks as a platform. Then set each truss inverted between the forks and set it upside down on the beams. Then I could climb up to the platform and rotate the truss to the correct position while a friend nailed it in place.
x_20170828_NewPoleShed (2).jpgx_20170828_NewPoleShed (5).jpgx-20170828_NewPoleShed (1).jpg
   / Need to come up with a "crane" to lift trusses #44
Well, this will be an anticlimactic finish for me. I called the lumber yard again and they assured me that if I could get my vehicle in there, then they would be able to get their boom truck in there also. So it's a bit embarrassing for me to have to admit that I won't have to build anything. They will lift the trusses up onto the walls. They will lay them flat so we can slide them into place and rotate them up.
   / Need to come up with a "crane" to lift trusses #46
How will they lay them flat on top of the headers?
John Deere 1025R (A53317)
John Deere 1025R...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2012 PETERBILT 388 WINCH TRUCKS (A58214)
2012 PETERBILT 388...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
