Need TIG machine purchase advice
   / Need TIG machine purchase advice #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
How much of a TIG welder would I need and how much would it cost?
I'm a somewhat intermediate MIG hobby welder and almost always work with mild steel for farm fabrication or street rod things. While MIG is nice, I'm thinking of buying a Lincold TIG machine to use for the same things and some aluminum as well. The prettier welds look better on nice cars and it's less mess in a nice shop. It would be more convenient to practice and I want to get into aluminum.
My question involves what I need and that gets me to price. I have been told I must have water cooled and a foot pedal to do aluminum because scratch start fouls the tip. Adult Ed at a tech school is my only experience with TIG and it was water cooled and foot pedal so I don't know any different. I really liked that setup but those features in a Lincold welder is around $5,000. Wow. Is that the way it is or are there alternatives or any directions to point me? I'm not sure what I want to do yet but thinking about it.
   / Need TIG machine purchase advice #2
Millet makes a nice little welder for ac aluminum called a diversion rins off 110 or 220 for 1700$ only dray back is it's limited to thin materials.I think it's limited to 3/16 aluminum
   / Need TIG machine purchase advice #3
starting out i would look at a miller syncrowave 200 with a w-17 air cooled torch.you also need a bottle of argon.this machine can stick weld also.
   / Need TIG machine purchase advice #4
If you're going to get into aluminum work with Tig. Dust off your wallet! And if you plan on doing any work on thicker aluminum, you may want to take quite a few aspirin because it's really going to hurt!:eek:
My 300-amp Tig welder really struggles with 3/8-inch thick aluminum, especially if it's of any size.
Water cooled torches are nice because they are smaller than air cooled. Yes you need a foot pedal or hand control when doing aluminum, you start out with high amps, then start backing off the amps as you continue to weld.
   / Need TIG machine purchase advice #5
I bought a Miller Diversion right after the machines were introduced. I bought it to do thin aluminum and SS. The previous reply is correct in that it will only do thin aluminum. I've tried one time to repair a larger aluminum casting. The thermal overloads tripped before a good puddle had formed, let alone start traveling with a bead. Its a good machine, but it is limited. I have an advantage over most folks by having access to a Synchrowave 350 at work. If you are set on doing aluminum, be prepared to pay.
So all of this, taken together, means it's over $5,500 for a 275 Miller with a foot pedal. The water cooled is nice but it it necessary or at least important for aluminum? That is indeed a difficult price unless I can somehow justify it. Maybe I can look for something used.
   / Need TIG machine purchase advice #7
I dont think you ever mentioned how thick you are wanting to weld on the aluminum side???
And no, the water cooler is not necessary, just a luxury.
When you say "I want to start getting into aluminum", if by that you mean smaller stuff like under 1/4", you dont need to spend 6k on a 350A welder. Right now at work, our only way to weld aluminum is with a POS spool gun or stick. Our tig is DC only. Its a miller maxstar 200. I have got the boss convinced to get us a dynasty 200 now. Basically the same welder but adds AC capability. He is getting quotes of $3k for just the machine. Which is fine for us because the torch and foot pedal from the maxstar will work. But you will have to spend ~$500-$800 for those. But $3800 is way better than $5500 if you dont plan to go much over 1/4"
   / Need TIG machine purchase advice #9
I hope so. Now hes just trying to figure out what to do with the old maxstar. I think he is going to sell it outright on ebay. He was trying to find a place that would take it in on trade, but no one wanted it. It is a **** nice welder thought, just lacking AC:mad: I love welding stainless with that machine:thumbsup:
Shield Arc and LD1----Can you tell me more about this Dynasty 200? Dynasty 300?
My only experience is with a Lincoln 350? or ? water cooled with a foot pedal and I really liked it.
My aluminum thickness would almost always be less than 1/4". Maybe 1/8" or less to the 3/16" range. I would like to do mild steel but some aluminum as well. What steel thickness would work for this machine as there are times I would like to go a little more than 1/4" to 5/16"?
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
2016 JOHN DEERE R4038 LOT NUMBER 195 (A53084)
2016 JOHN DEERE...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
12in Backhoe Bucket (A52748)
12in Backhoe...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
City of Buckhannon - 2000 Chevy 2500 (A52384)
City of Buckhannon...
