Need starter
/ Need starter #1
playing in the dirt
Massey 135
I have a Ingersoll 3014 with a 14 hp. Briggs Vanguard engine. I need a starter. On the Briggs site it tells me I need a # 691564 starter but this is not correct.
I have a Model 294447 , Serial # is 94070511, spec # is 0445-02 3441. Mine has a steel flywheel with a 16 tooth nylon gear on starter. It measures between end caps 4 3/8" and the drive is held on by a roll pin. Also mounting end cap is Alum cast. The #691564 is a 15 tooth starter and is shorter between end caps. Can someone please tell me what I need . Thanks.
/ Need starter #2
If you want the correct starter, then here's the man to contact.
Brian Hildreth*
Salem Power Equipment,*LLC *
6430 Napier Road
Plymouth, MI 48170
(734) 649-*‐1781
*bhildret@aol.com
salempwr@aol.com
/ Need starter
Thank you very much Hydriv for the info. I will contact him today .
2007 Toyota Tundra 4x4 Ext. Cab Pickup Truck (A64556)
2007 Toyota Tundra...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A64553)
2021 Wacker Neuson...
Shortstop 2Yd Towable Concrete Mixer (A64553)
Shortstop 2Yd...
LONG PTO 5" X 6" IRRIGATION PUMP (A64278)
LONG PTO 5" X 6"...
2026 SDLANCH SDLC1220 High-End Carport (A64194)
2026 SDLANCH...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
