Need starter
/ Need starter #1
playing in the dirt
Massey 135
I have a Ingersoll 3014 with a 14 hp. Briggs Vanguard engine. I need a starter. On the Briggs site it tells me I need a # 691564 starter but this is not correct.
I have a Model 294447 , Serial # is 94070511, spec # is 0445-02 3441. Mine has a steel flywheel with a 16 tooth nylon gear on starter. It measures between end caps 4 3/8" and the drive is held on by a roll pin. Also mounting end cap is Alum cast. The #691564 is a 15 tooth starter and is shorter between end caps. Can someone please tell me what I need . Thanks.
/ Need starter #2
If you want the correct starter, then here's the man to contact.
Brian Hildreth*
Salem Power Equipment,*LLC *
6430 Napier Road
Plymouth, MI 48170
(734) 649-*‐1781
*bhildret@aol.com
salempwr@aol.com
/ Need starter
Thank you very much Hydriv for the info. I will contact him today .
2016 CATERPILLAR 299D2 SKID STEER (A63276)
2016 CATERPILLAR...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
2015 Peterbilt 348 T/A 24ft Chemical Transport Flatbed Truck (A64194)
2015 Peterbilt 348...
Kubota L3901HST
Kubota L3901HST
2022 CATERPILLAR 950M WHEEL LOADER (A65053)
2022 CATERPILLAR...
John Deere 2840 Tractor (A64047)
John Deere 2840...
