Need some welding advice
/ Need some welding advice #22
Check the feed tension, it might be a tad loose. If the wire stops feeding momentarily it will cause what you've described.
Sean
Check here frist as Chilly has said.It happened to me.
Army Grunt
/ Need some welding advice #23
Gary if you think that is tough, try diagnosing someone's problem with a Mig welder via the Internet.
A lot easier when you can see it, and listen to it in person.;)
Also agreed.......You may need another trained set of eyes and ears to watch while you are welding......could be simple fix/adjustment....
/ Need some welding advice #24
Could be the gas, could be holding the tip too high, could be going too fast... might want to ask some skilled welder to watch you and figure it out.
/ Need some welding advice #25
You should have good handiness and concentration during work. You should have knowledge about the material you are using and care taken during use of it in welding. You can try flux-cored arc welding. It may work better.
Logsplitters Ireland
207280 (A52708)
207280 (A52708)
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
2014 Ford Flex SUV (A59231)
2014 Ford Flex SUV...
2008 MAXX-D FUEL TRAILER (A58214)
2008 MAXX-D FUEL...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
