Need some welding advice
/ Need some welding advice #22
Check the feed tension, it might be a tad loose. If the wire stops feeding momentarily it will cause what you've described.
Sean
Check here frist as Chilly has said.It happened to me.
Army Grunt
/ Need some welding advice #23
Gary if you think that is tough, try diagnosing someone's problem with a Mig welder via the Internet.
A lot easier when you can see it, and listen to it in person.;)
Also agreed.......You may need another trained set of eyes and ears to watch while you are welding......could be simple fix/adjustment....
/ Need some welding advice #24
Could be the gas, could be holding the tip too high, could be going too fast... might want to ask some skilled welder to watch you and figure it out.
/ Need some welding advice #25
You should have good handiness and concentration during work. You should have knowledge about the material you are using and care taken during use of it in welding. You can try flux-cored arc welding. It may work better.
Logsplitters Ireland
2008 MACK CHU613 (INOPERABLE) (A67714)
2008 MACK CHU613...
DEERE 410J Engine (A68134)
DEERE 410J Engine...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2021 PETERBILT 367 (A67714)
2021 PETERBILT 367...
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
