Need John Deere top link dimension...
/ Need John Deere top link dimension... #1
mbu
Colorado
If you have a John Deere Category 2 top link similar to the one shown in the attached photo (part # AR34209) would you mind obtaining a measurement for me?
I need to know the minimum and max distance it will screw to.
Thank you for your help!
Mike
/ Need John Deere top link dimension... #2
I have a JD 5525 with cat two but it does not look like this one. Willing to measure for you if it would help. It is not being used right now so would be easy. It maybe the model of tractor is more important than the design of the third arm is.
kthompson,
Thank you!
The photo in my post is the best one I could find that looks similar to the JD's. If yours has a hook on one end (like in my first post photo) and a knuckle on the other (like in the attached photo below) that'll be the one I'm looking for. If you have time, I'd sure appreciate the dimensions of when it's screwed tight and when it's screwed open. I believe, the John Deere part number is AR34209.
/ Need John Deere top link dimension... #4
Mike
Top Link Assembly
John Deere - Fits: 520, 530, 620, 630, 720, 730
Replaces: AF2799R, AR21917R, AF2873R, AF2798R
This John Deere top link includes the hood on the end and the chain. Adjustable from 21-1/2" to 30". Uses a 0.750" diameter pin in one end and a 2" diameter ball in the hook end.
You can buy one from here...:)
John Deere Tractor Hitch Top Links and Replacement Parts
Top Link Assembly
Thank you for the link! That is the information I needed.
2022 EZ-GO ELITE...
USA Flag Metal Sign (A64557)
USA Flag Metal...
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
2022 EZ-GO ELITE...
2021 GMC Sierra 1500 Crew Cab Pickup Truck (A64556)
2021 GMC Sierra...
2015 Scag Turf Tiger 60in Zero Turn Commercial Mower (A64553)
2015 Scag Turf...
