3-Point Hitch need help
/ need help #1
cthompson
Mayflower AR
Mahindra 6110
I have A Mahindra 6110 got 220 hours the 3 point hitch is stuck all the way up i've tried the lock did not help
/ need help #2
Don't have your model tractor... but most tractors have a three point 'drop rate' valve [ or whatever you want to call it ] located usually down by your heels under the seat... or around the seat area. It is real easy to kick that thing a few times and shut the flow off so much that the three point will not go down. Just an idea....
/ need help #3
:welcome:
From Alabama.
/ need help #4
Pls call your dealer...hopefully with only 220 on the clock its still under complete warranty....ALSO, pls let us know what happens with the dealer...just in case. Good Luck. BobG in VA
/ need help #5
this..it's a large black knob. It took me a while before I realized that was my problem too. Unscrew it and the 3pt will drop.
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
