3-Point Hitch need help
/ need help #1
cthompson
Mayflower AR
Mahindra 6110
I have A Mahindra 6110 got 220 hours the 3 point hitch is stuck all the way up i've tried the lock did not help
/ need help #2
Don't have your model tractor... but most tractors have a three point 'drop rate' valve [ or whatever you want to call it ] located usually down by your heels under the seat... or around the seat area. It is real easy to kick that thing a few times and shut the flow off so much that the three point will not go down. Just an idea....
/ need help #3
:welcome:
From Alabama.
/ need help #4
Pls call your dealer...hopefully with only 220 on the clock its still under complete warranty....ALSO, pls let us know what happens with the dealer...just in case. Good Luck. BobG in VA
/ need help #5
this..it's a large black knob. It took me a while before I realized that was my problem too. Unscrew it and the 3pt will drop.
2019 Ford Explorer AWD SUV (A66738)
2019 Ford Explorer...
48" Canal Pump (A64912)
48" Canal Pump...
2013 WACKER NEUSON HF 690 FLAMELESS HEATER (INOPERABLE) (A68842)
2013 WACKER NEUSON...
2012 Dodge Grand Caravan Van (A66738)
2012 Dodge Grand...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
2009 POLAR TANK . (A67714)
2009 POLAR TANK ...
