Need Help!!
/ Need Help!! #1
darcypid
Vegreville,Alberta
Hi to all!
I am a horse owner on a 25 acre acreage.I need a tractor for moving snow,and just big enough that I could move around round bale.I would need 4x4 and a cab,In the 20000-30000 price range.What do you all recomend?
/ Need Help!! #2
Hi to all!
Depending on your local tractor market and whether you want new or used, I would think a 50 HP. tractor would be just fine and if you want to move snow you would want a front end loader with a quick attach so you could use a blower, plow, bucket or hay spear or a cheaper way would be to use the 3 point hitch for a hay spear, blower or back blade. So much of this is your own preference but with your budget you should have no problem.
/ Need Help!! #3
If you look at used ones, you may be OK, but to get what you named; i.e., cab, 4WD, and big enough to lift round bales, it might be tough to find something in your price range. If you want to use something like a Hay King 3-point hay spear instead of lifting round bales with a front end loader, you might have a better chance of stayng within your budget.
/ Need Help!! #4
4wd and a cab puts you into an 80's+ machine if looking used.
I agree that a 45 or so hp machine will be where you want to look.. anything smaller is dicey with rounds.
soundguy
2014 MERCEDES 2500 CARGO VAN (A59911)
2014 MERCEDES 2500...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2016 John Deere 1795 Planter (A63109)
2016 John Deere...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
