Need Help!!
/ Need Help!! #1
darcypid
Vegreville,Alberta
Hi to all!
I am a horse owner on a 25 acre acreage.I need a tractor for moving snow,and just big enough that I could move around round bale.I would need 4x4 and a cab,In the 20000-30000 price range.What do you all recomend?
/ Need Help!! #2
Hi to all!
Depending on your local tractor market and whether you want new or used, I would think a 50 HP. tractor would be just fine and if you want to move snow you would want a front end loader with a quick attach so you could use a blower, plow, bucket or hay spear or a cheaper way would be to use the 3 point hitch for a hay spear, blower or back blade. So much of this is your own preference but with your budget you should have no problem.
/ Need Help!! #3
If you look at used ones, you may be OK, but to get what you named; i.e., cab, 4WD, and big enough to lift round bales, it might be tough to find something in your price range. If you want to use something like a Hay King 3-point hay spear instead of lifting round bales with a front end loader, you might have a better chance of stayng within your budget.
/ Need Help!! #4
4wd and a cab puts you into an 80's+ machine if looking used.
I agree that a 45 or so hp machine will be where you want to look.. anything smaller is dicey with rounds.
soundguy
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
HARDEE MR1442 - 4' DITCH BANK CUTTER (A63290)
HARDEE MR1442 - 4'...
JOHN BLUE 300 GALLON NITROGEN APPLICATOR (A63290)
JOHN BLUE 300...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2023 John Deere 9RX 540 Track Tractor (A63109)
2023 John Deere...
PALLET LOT OF MISC METAL (A63745)
PALLET LOT OF MISC...
