Need help with tire chains
/ Need help with tire chains #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So I broke down and purchased 2sets of diamond pattern chains. I never have really messed much with chains so excuse my ignorance here. I got them on just fine, but when I connected the two top chains ( the ones holding the diamond pattern together) I noticed they had sent these odd d rings. The straight part of the d was a screw. I opened the screw put the chains together and wrenched them down. Well, long story short after thoroughly enjoying the new found traction on 45 degree slopes I returned to find a number of my d rings missing. Can you guys recommend something better?
/ Need help with tire chains #2
D-rings mean different things to different folks ...pic or diagram? pointer to your chains or seller?
/ Need help with tire chains #3
I think the D ring you are talking about has a threaded pin with an eye on top. I safety wire my D rings with the wire running through the eye.
/ Need help with tire chains #4
Are you talking about shackles? If so I slightly modify them. On the pin I put an o-ring and on the outside of the non threaded hole I countersink it just a little bit. When you tighten the pin the o-ring squish out. I found a good place to buy them is Lowes, they have stainless ones for pretty cheap.
Well. I had them installed wrong to begin with. Ken Simolo provided me with pix that showed me what I was doing wrong. Yes... Clevis. I bought some replacements and re ran the chains. Found some chain tensioners and already broke one. Will run the safety wire.
Thanks for all the advice.
Carl
/ Need help with tire chains #8
Bungee cord tensioners work well & are about free. I run two on the inside (+) , & three on the outside. (*). They held up fine thru a naty winter here last year.
wolverine Skid Steer Stump Grinder (A64047)
wolverine Skid...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
