Need help with tire chains
/ Need help with tire chains #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So I broke down and purchased 2sets of diamond pattern chains. I never have really messed much with chains so excuse my ignorance here. I got them on just fine, but when I connected the two top chains ( the ones holding the diamond pattern together) I noticed they had sent these odd d rings. The straight part of the d was a screw. I opened the screw put the chains together and wrenched them down. Well, long story short after thoroughly enjoying the new found traction on 45 degree slopes I returned to find a number of my d rings missing. Can you guys recommend something better?
/ Need help with tire chains #2
D-rings mean different things to different folks ...pic or diagram? pointer to your chains or seller?
/ Need help with tire chains #3
I think the D ring you are talking about has a threaded pin with an eye on top. I safety wire my D rings with the wire running through the eye.
/ Need help with tire chains #4
Are you talking about shackles? If so I slightly modify them. On the pin I put an o-ring and on the outside of the non threaded hole I countersink it just a little bit. When you tighten the pin the o-ring squish out. I found a good place to buy them is Lowes, they have stainless ones for pretty cheap.
Well. I had them installed wrong to begin with. Ken Simolo provided me with pix that showed me what I was doing wrong. Yes... Clevis. I bought some replacements and re ran the chains. Found some chain tensioners and already broke one. Will run the safety wire.
Thanks for all the advice.
Carl
/ Need help with tire chains #8
Bungee cord tensioners work well & are about free. I run two on the inside (+) , & three on the outside. (*). They held up fine thru a naty winter here last year.
2000 Kubota KX61-2 (A60462)
2000 Kubota KX61-2...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2018 Kubota U17 (A53317)
2018 Kubota U17...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
