Need help with purchase of weight distribution hitch
   / Need help with purchase of weight distribution hitch #71
Anyone addressed the issue with 2 different tow capacities? I have the camper at 6K lbs, then my tractor with implements and trailer combined weight of about 9K. Can I get a 10K WD hitch to work for both? Or is the camper too light?
   / Need help with purchase of weight distribution hitch #72
The same hitch should work for both. However you may need different spring bars for the different weight trailers.
   / Need help with purchase of weight distribution hitch #73
On mine you can change the # of chain links you put in the cam to change bend on the bars for different weights. I just did a 3.5hr tow(15k lbs) for the first time with the wd hitch that I've done without a few times before without. So much more pleasant, there are some undulations on the Chesapeake bay Bridge tunnel that really got it unpleasantly bobbing up and down without the wd hitch. It was comfortable with the hitch and I didn't have people flashing high beams at me since I got home after dark.
   / Need help with purchase of weight distribution hitch #74
Yes, as mentioned above, you just don't tighten the chains up as much with a light load or empty trailer.
   / Need help with purchase of weight distribution hitch #75
When the RV dealer setup my 9k gross weight trailer and truck hitch they used a 12k WDH, including the bars. My actual towing weight was 7.5k, and it always towed fine.
As mentioned, the bar tension on hitches I am familiar with have adjustable chain links to increase or reduce the bar tension.
   / Need help with purchase of weight distribution hitch #76
I have the 14K https://www.equalizerhitch.com/ which uses bars for my RV and sometimes we use the RV empty or with the ATV's or a TJ loaded so the weight varies but I have never needed to adjust anything because the it's all about the tongue weight, As long as the bars are strong enough to provide enough force/weight transfer of the heaviest load it will provide less when the RV/hitch weight is lighter.
   / Need help with purchase of weight distribution hitch #77
You're fine to use the same WD hitch on different trailer weights. anything in the 6,000-10,000 lb capacity probably uses the same bars (same size, material, heat treat).
   / Need help with purchase of weight distribution hitch #78
OK, so I move slow. I'm the OP and this is what I bought. Got it on Amazon for $318 and I'm ready to use it soon. It seemed like the best $$ and it was the type that would not interfere with my chain basket.
It has a sway control bar that I probably will not mount because it requires drilling into the side of my trailer frame and I'm not sure I should do that.
It's a CornPro UT-18H open trailer as shown below. I usually haul 7,000-8,000 lbs but sometimes 10,000.
Thank you all for your help and guidance.
That's a solid design. I would attach the sway control though. Either bolt it on or weld it on, you'll want it when it starts to wag back there! Otherwise you could have bought the TruTrack by Curt, that one requires no trailer drilling and uses active sway control, preventing sway from starting.
   / Need help with purchase of weight distribution hitch #79
This is a picture that might lead you to believe it’s a class V hitch. I don’t know what the V-5 means but not class V.
The last Chevy 3/4 ton I had appeared you didn’t need a WD hitch for something up to about 11,500 pounds, at least that’s what the hitch sticker said. I didn’t read the manual close enough to see if it said other wise.
V-5 is an old standard for testing this hitch. The industry has gone to SAE J684 for receiver hitches and SAE J2638 for gooseneck/5th wheel hitches. Really the whole "class" system is a joke as you'll find "class 3" receiver tubes on 2,000 lb rated hitches for vehicles "not rated to tow". Remember, it's always follow the lowest rated component of the towing system. If the car's not rated to tow, your overweight.
State laws can override when a WD hitch is required. I know some states require a WD hitch on anything over 6K lbs.
   / Need help with purchase of weight distribution hitch #80
Curt says this: Also, the receiver is not rated any higher than the ball mount/drawbar. There are also differences between OEM hitches and aftermarket. A lot of 2" are class 5.
"Class 5 hitches are a bit different from other hitch class ratings, as this class is not officially recognized by the Society of Automotive Engineers (SAE). This means that the information on how much the hitch can safely tow should be verified by the manufacturer."
Curt also has their industrial class 5 hitches with a 2.5" receiver tube. Class 5 hitches are tested with extrapolated numbers to the higher ratings. There is a SAE 20K taskforce in the works but nothing has been published yet for test requirements. They should bump it up to 40K as Ford went ahead and jumped their darn ratings yet again!
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
