Need help with purchase of weight distribution hitch
   / Need help with purchase of weight distribution hitch
OK, so I move slow. I'm the OP and this is what I bought. Got it on Amazon for $318 and I'm ready to use it soon. It seemed like the best $$ and it was the type that would not interfere with my chain basket.
It has a sway control bar that I probably will not mount because it requires drilling into the side of my trailer frame and I'm not sure I should do that.
It's a CornPro UT-18H open trailer as shown below. I usually haul 7,000-8,000 lbs but sometimes 10,000.
Thank you all for your help and guidance.
   / Need help with purchase of weight distribution hitch #62
You should be happy with that setup. May be harder to lock into place than you had to be since they are rated for 14K pounds and only pulling 10K trailers.
Help me understand that. My trailer is pretty rugged and rated 12,000 lbs. The same trailer with bigger axles is rated 14,000 lbs. Why does the amount I'm pulling matter?
Another question. When driving a tractor up onto a flat trailer with a weight distribution hitch, can I feel the pressure on the tongue of the trailer so I know I have sufficient tongue weight?
   / Need help with purchase of weight distribution hitch #65
That's really two separate things. Position the tractor so there's sufficient tongue weight, then use the WD to bring the rear of the tow vehicle back up.
   / Need help with purchase of weight distribution hitch #66
I also load the trailer before setting the spring bars, watching for the truck rear to drop a few inches. I then take some weight off with the trailer jack to make setting the spring bars easier. When loading the spring bars I confirm that the rear of the truck goes back to unloaded height, or close to it.
That's just ballpark close though. For loads I trailer frequently I scale the tongue weight with a small RV type hydraulic scale and mark the trailer.
   / Need help with purchase of weight distribution hitch #67
The higher weight rating on the distribution hitch, the stiffer the bars are. I have 2 WD hitches, a 6000 lb set for my camper and a 14000 lb set for my equipment trailer. The 14000 is much harder to set the bars. It doesn't matter how much the trailer weighs.
   / Need help with purchase of weight distribution hitch #68
The instructions should help you with this. Remember, the purpose of the weight distribution is to insure the correct amount of weight is on both front and rear axle of the vehicle so that the steering will not be affected by too much weight on the rear axle. When you set it up, the instructions will probably ask you to measure the height of both the front and rear of the truck to insure they don't change very much.
After it is set up, the more weight on the tongue, the more pressure on the torsion bars, and more weight transferred to the front axle.
Usually, when setting it up, they will ask that you set the trailer level and adjust the truck hitch a little higher than the hitch (about 1/2 to one inch) to start.
You probably already know all this.
It does take time to hook up your trailer with WD. If I am carrying a heavy load (tractor and implements), I figure on allowing about 30 minutes for hookup. It is easier for me to NOT use the trailer jack, but to use a bottle jack when hooking up. The more weight you put on the torsion bars at hookup, and the longer it may take to hookup.
I always scale a heavy load at a CAT scale. It will show if the front axle is light and the rear axle is carrying too much weight. Use CAT app. It will shoe the weight of each axle, both vehicle axles and the trailer axle. CAT scale cost $13.50 to weigh - $3.50 if you need to rescale.
Then - how does it feel when you drive it - too bouncy - feel heavy on the road bumps, rear sways too much. All issues you may wan to correct. Best Wishes
   / Need help with purchase of weight distribution hitch #69
Once you start paying attention to tow ratings and requirements you notice alot of trucks out towing equipment that should have WD hitches but don't. Probably 90% towing stuff without a WD hitch that the manual says needs one a 10% that actually use one.
   / Need help with purchase of weight distribution hitch #70
True. I towed a 7k landscape trailer for years without needing a WD hitch. Technically if I was at the 7k GTWR I should have used a WD hitch, as my truck specifies 6k and heavier requires WD.
When I recently upgraded my trailer to a 12k WD became mandatory with more than about 3.3k of cargo.
   / Need help with purchase of weight distribution hitch #71
Anyone addressed the issue with 2 different tow capacities? I have the camper at 6K lbs, then my tractor with implements and trailer combined weight of about 9K. Can I get a 10K WD hitch to work for both? Or is the camper too light?
   / Need help with purchase of weight distribution hitch #72
The same hitch should work for both. However you may need different spring bars for the different weight trailers.
   / Need help with purchase of weight distribution hitch #73
On mine you can change the # of chain links you put in the cam to change bend on the bars for different weights. I just did a 3.5hr tow(15k lbs) for the first time with the wd hitch that I've done without a few times before without. So much more pleasant, there are some undulations on the Chesapeake bay Bridge tunnel that really got it unpleasantly bobbing up and down without the wd hitch. It was comfortable with the hitch and I didn't have people flashing high beams at me since I got home after dark.
   / Need help with purchase of weight distribution hitch #74
Yes, as mentioned above, you just don't tighten the chains up as much with a light load or empty trailer.
   / Need help with purchase of weight distribution hitch #75
When the RV dealer setup my 9k gross weight trailer and truck hitch they used a 12k WDH, including the bars. My actual towing weight was 7.5k, and it always towed fine.
As mentioned, the bar tension on hitches I am familiar with have adjustable chain links to increase or reduce the bar tension.
   / Need help with purchase of weight distribution hitch #76
I have the 14K https://www.equalizerhitch.com/ which uses bars for my RV and sometimes we use the RV empty or with the ATV's or a TJ loaded so the weight varies but I have never needed to adjust anything because the it's all about the tongue weight, As long as the bars are strong enough to provide enough force/weight transfer of the heaviest load it will provide less when the RV/hitch weight is lighter.
   / Need help with purchase of weight distribution hitch #77
You're fine to use the same WD hitch on different trailer weights. anything in the 6,000-10,000 lb capacity probably uses the same bars (same size, material, heat treat).
   / Need help with purchase of weight distribution hitch #78
That's a solid design. I would attach the sway control though. Either bolt it on or weld it on, you'll want it when it starts to wag back there! Otherwise you could have bought the TruTrack by Curt, that one requires no trailer drilling and uses active sway control, preventing sway from starting.
   / Need help with purchase of weight distribution hitch #79
This is a picture that might lead you to believe it’s a class V hitch. I don’t know what the V-5 means but not class V.
The last Chevy 3/4 ton I had appeared you didn’t need a WD hitch for something up to about 11,500 pounds, at least that’s what the hitch sticker said. I didn’t read the manual close enough to see if it said other wise.
V-5 is an old standard for testing this hitch. The industry has gone to SAE J684 for receiver hitches and SAE J2638 for gooseneck/5th wheel hitches. Really the whole "class" system is a joke as you'll find "class 3" receiver tubes on 2,000 lb rated hitches for vehicles "not rated to tow". Remember, it's always follow the lowest rated component of the towing system. If the car's not rated to tow, your overweight.
State laws can override when a WD hitch is required. I know some states require a WD hitch on anything over 6K lbs.
   / Need help with purchase of weight distribution hitch #80
Curt says this: Also, the receiver is not rated any higher than the ball mount/drawbar. There are also differences between OEM hitches and aftermarket. A lot of 2" are class 5.
"Class 5 hitches are a bit different from other hitch class ratings, as this class is not officially recognized by the Society of Automotive Engineers (SAE). This means that the information on how much the hitch can safely tow should be verified by the manufacturer."
Curt also has their industrial class 5 hitches with a 2.5" receiver tube. Class 5 hitches are tested with extrapolated numbers to the higher ratings. There is a SAE 20K taskforce in the works but nothing has been published yet for test requirements. They should bump it up to 40K as Ford went ahead and jumped their darn ratings yet again!
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
Commercial truck Frame with Axle (A59230)
Commercial truck...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A59228)
2010 Turfco...
