Need help with my geometry
   / Need help with my geometry #91
Wonder what percentage of High School students could use one??? HE**,,,, wonder what percentage of High School Teachers could use one???? :)
Back in my day, anyone who took anything beyond general math or general science, (9th grade) would know how to use one. So roughly I would say 1/3 of the students. Today?. I would say zero percent. Most would not even know what it was.
   / Need help with my geometry #92
An awful lot of engineering and science was completed with the aid of a slide rule. It was apparently good enough. Oh, and they don't need batteries.:)
I asked my 20 year old nephew if he knew what a slide rule was. He almost instantly quoted me:
"The Slide Rule 7.08
THERE IS NO "MUST SLIDE" RULE!!!
Rule 7.08 - Any runner is out when -
(a) (3) the runner does not slide OR attempt to get around a fielder who HAS THE BALL and is waiting to make the tag.
The key phrases here are: "or attempt to get around" and "has the ball waiting to make the tag."
The runner may slide or attempt to get around the fielder. He does not have to slide. Plus, unless the fielder has the ball, the runner doesn't have to do either.
The purpose of the rule is to prohibit the runner from deliberately crashing into a defender who has the ball, for the sole purpose of knocking the ball loose, because the runner knows he is going to be out otherwise.
The fielder should not be in the base path without possession of the ball. If he is it is obstruction. Anytime a runner deliberately and maliciously crashes into a fielder he should be ejected for unsportsmanlike conduct. However, if a close play occurs and the runner does not slide and makes incidental contact with the defender before he has the ball, no call should be made. If the defender has the ball, the umpire should judge as to whether the runner made an attempt to get around the fielder. If he did, he should not be called out simply because he did not slide or made contact.
In attempting to get around a fielder who has the ball waiting to make the tag, the runner must not run more than 3 feet to either side of a line that goes between him and the base he is advancing to. If he does, he is out for violation of rule 7.08 (a) (1)
AAHHHH!!!!!
I wonder if he knows what carbon paper is?
   / Need help with my geometry #94
I still have and use my original TI-30 LED calculator. It is from 1976
My first calculator I've had several versions of these.
I've still got a couple floating around somewhere. They don't need no stinkin batteries.
even this kind
I think they might even still make them but I still have mine.
When I was doing geodetic work we couldn't use any sort of slide rule because they weren't accurate enough so we had to haul these things around along with big books of trig functions etc.
I'd seen four function calculators in Japan but when these came out, I bought one and was in hog heaven.
It had scientific notation, reciprocal along with square and square root. I was in tall cotton for sure. SR was for Slide Rule. I could use it for some stuff but not the trig work.
Then HP came out with the HP65. I think it was the first user programmable and used magnetic strips to store your programs. I believe they hit on our outfit to give it a good workout before it was broadly introduced because we had to crank so many numbers. I could even do octal math on the thing. Truly a gift of the gods.
It even took the place of the big Wangs back at HQ and I think the computer section was even a little envious. I was in love because I didn't have to drag that boat anchor of a Monroe along with all those heavy books anymore. It saved me hours and hours plus I didn't have to crank the thing. I was branded and am still a fan and lifelong convert to RPN, it's the only way to fly.
   / Need help with my geometry #95
The question is would they even know what one was? :laughing:
   / Need help with my geometry #96
They just about put man on the moon with them.
   / Need help with my geometry #97
Ah, yes RPN... (Reverse Polish Notation)...
   / Need help with my geometry #98
Im sure my dad has, and can still proficiently use, a slide rule. As a kid (I was home schooled in the '80's and early 90's) dad made sure I knew what one was, showed me how to use it, which I've forgot since then. He always carried note cards in his shirt pocket, old computer punch cards... he found them great for making notes on...
   / Need help with my geometry #99
We used to make Christmas wreaths out of them.
   / Need help with my geometry #100
Then he might know what these are too.
I used to have to read five level tape but it was only good for base 8 or octal. Eventually got to where I could add and subtract but had to convert to do anything more with it. It was easy to get cross eyed and lose your place.
Things are much easier today.
2021 FREIGHTLINER CASCADIA SLEEPER TRUCK (A51219)
2021 FREIGHTLINER...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52128)
Adams FL24...
E-Z Trail 680 Adjustable Head Cart (A50514)
E-Z Trail 680...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
Payment Terms (MUST READ) (A50775)
Payment Terms...
