Need help with my geometry
   / Need help with my geometry #31
Math my way. :)
Bruce
   / Need help with my geometry #33
There is enough info. Look at it as 2 right triangles plus a rectangle in the middle. Find height by using Pythagoras's theorem. At 81 I don't recall the math.
Yet another way to solve it. Now it is all Pathagorean.View attachment 465621
Correct. And since both right triangles are identical to each other, you could combine them to get a rectangle. That rectangle can be combined to the rectangle in the middle giving you just one larger rectangle. The dimensions of that rectangle are 20 ft x 21.81742 ft. The area is 436.348 sq ft.
   / Need help with my geometry #34
Yep...we already told them that, but did they believe us? NO! :thumbsup:
   / Need help with my geometry #35
It should be 24x24 - 10x10
Yep. Didn't pass the funny look test. Leg cannot be longer than hypotenuse. Leg (height of the trapezoid) is 21.8.
So 21.8 x 10 (2 triangles) + 10 x 10 (rectangle in between) = 318.2 sq.ft.
Somehow thought about this in doctor's office this morning.
Ralph
   / Need help with my geometry #36
Sorry I did not get in on this in time to work this one. I love working these. a^2 +b^2=c^2 or in words, the square of the hypotenuse equals the sum of the squares of the other two sides. Must be a right triangle of course. Once a nerd, always a nerd I guess.
   / Need help with my geometry #37
I hear ya! I felt the same way, still had to do the math, found the answer had been given, and was a little sad I didn't get to help. :)
   / Need help with my geometry #38
Using common core I say its 615.1. You just can't argue with common core. I can't be wrong, It'll hurt my feelings.
   / Need help with my geometry #39
   / Need help with my geometry #40
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
2000 Mercedes-Benz S-Class Sedan (A50324)
2000 Mercedes-Benz...
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
