Need help with Canopy design
/ Need help with Canopy design #1
Charliebrn
Platinum Member
NW Ohio
Kubota BX-2360
Hey guys and gals, I need some help. I just picked up a cab roof from a Curtis Cab that came into my dealer scratched. To make a long story short, I bought it for a decent price and want to make a canopy out of it. Since this was designed as a cab roof (In other words, it attached to the sides of the cab which supported it), I have no way of mounting it. It is made of a fairly heavy gauge of steel, and weighs something like 60lbs. I figure on making a frame that I'm going to clamp to my ROPS, but I'm wondering if a couple braces angled up from the rops to the front of the canopy will support it properly. I want to try and minimize the vibration on it as much as possible for lights, etc.
I'd appreciate any ideas and if anyone has pictures of how their canopy is mounted, I'd sure appreciate it if you could post em....
Thanks in advance!!!
/ Need help with Canopy design #2
Hi Scott,
Sounds like you got a good deal on that cab top. You will probably find that even 60# isn't too hard to support. You probably won't even have to angle the supports up to the canopy. My canopy uses two lengths of square tubing running along the inside of the top for support. Picture is attached.
Yes, my canopy is fiberglass, and not as heavy as yours, but I think I could almost do pull-ups on the ends of those braces...if I could do pull-ups!! BuckTop ads show a pretty girl sitting on top of a mounted canopy.
The vibration issue has been discussed some in another thread somewhere. Can't remember all the options, but I think some sort of sound deadening spray is available. You can spray the underside of your canopy and quiet the vibration. My canopy is not treated for vibration...and it does vibrate at certain tractor speeds. Changing the tractor speed a little usually quiets it down...and with earplugs in, it's only a minor nusaince for me.
Good luck. Post pictures!
OkieG
/ Need help with Canopy design #3
Charlie I have a fiberglass canopy on my TC-40D. Firebird Fiberglass makes it. They use rubber isolators to eliminate vibration in their TracTop canopies. I am sure they would sell you a set of the rubber mounts to use with your rig. They can be reached here http://www.firebirdfiberglass.com
I also had an issue with my folding ROPS vibrating because of the TracTop but because the tractor is housed in a 14-foot pole barn with 10-foot doors I didn't need a folding ROPS. I removed the pins and replaced them with bolts and locknuts. The Rops is now permanent and it does not rattle.
Good luck on your project. /forums/images/graemlins/grin.gif
/ Need help with Canopy design #4
Try attatching it like my canopy is. The are angle iron brackets, and use 'U' bolts to attatch to the rops.. canopy and all.
Soundguy
/ Need help with Canopy design #5
Charlie I finally got around to taking a few pictures of my canopy mount since I am in the process of adding some halogen lights to compensate for when I am using my FEL.
Anyway, check out my picture. If you use the U-bolts like mine then you can adjust horizontally & vertically for your canopy. The design is quite simple. I also have more pictures if you need them just let me know.
/ Need help with Canopy design #6
Mike,
Is that a TBN'ers street sign hanging on the wall under the radio?? /forums/images/graemlins/shocked.gif /forums/images/graemlins/tongue.gif
Where'd you get that? Does Muhammad know there was a street named after his website??
Gonna have to send the TBN PO-lice after you to get that sign!! /forums/images/graemlins/grin.gif
/ Need help with Canopy design #7
<font color="blue"> Is that a TBN'ers street sign hanging on the wall under the radio??
</font>
OK you got me. I was hoping no one whould notice. Put the cuffs on me and take me away.
Actually my better half got that sign for me before I knew what TBN was. It is my last name EBNER, never got around to putting it up so it's home is the pole barn for now.
Too many other projects underway right now. I'm going to be up to my adams apple this Monday as I am having 40 tons of number 1s & 2s stone delivered for some drainage ditch work here at the ranch. I imagine that will keep me busy for a bit.
Wanna Help? /forums/images/graemlins/tongue.gif
Thanks to everyone. I think I have a design in mind and am going to try it out this weekend. Sort of a hybrid between your pics here and another tractor I saw on my way to work. If it works, I'll post pictures, if not, well, I think I'll try PineRidges solution to see if it will work. One think about this rooftop is that it is made of fairly heavy gauge metal and I'm hoping that i wont need bracing from front to back.
Thanks for the help everyone! /forums/images/graemlins/smile.gif
Scott
Well, here are the results... Pic 1
From the front...
And the rear...
/ Need help with Canopy design #12
Scott....... it looks great, but I only have one question..... do you ever use the loader???? no scratches??????? /forums/images/graemlins/confused.gif
*LOL* Gold star for noticing!!! Actually, for this project, I went out and bought a can of Allis Chalmers Orange paint at TSC. I repainted the bucket and touched up some scratches on the tractor just before I took the picture! Its a thick, brush on paint that matches the color perfectly, as you can see. A quart costs about $8.
But she doesn't look bad after 3 years and 300 hours... /forums/images/graemlins/grin.gif
/ Need help with Canopy design #14
Scott lookin pretty sharp.
Where did you pick up those aux. lamps?
The lamps were also picked up at TSC. They sell the same lamps in Flood, Traps, and spots. The fronts are both traps, One on the rear is a trap and one is a flood. The sides are fog lights, and are easily removable as I just need them for moving snow and avoiding vehicles. /forums/images/graemlins/blush.gif
/ Need help with Canopy design #16
Charle, for sound deadening glue an egg crate foam mattress to the underside of the canopy with an appropiate construction glue. Hospitals send them home with the patient or throw them away since they're impossible to sterilze. /forums/images/graemlins/wink.gif
That sounds like a great idea! The cab roof already has a padding/cloth material on the underside of the top, so I'll see how it does, but if it's noisy at all under there, I'll sure try that.
thanks!
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
2011 JET  48 FOOT SPREAD AXLE STEP DECK TRAILER (A67714)
2011 JET 48 FOOT...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2025 Auger with Bits Mini Excavator Attachment (A66734)
2025 Auger with...
2010 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2010 Ford F-150...
GENERAC MOBILE  MTL65 LIGHT PLANT (INOPERABLE) (A68842)
GENERAC MOBILE...
